  2. Allegro X Scripting - TCL
  3. Copying one part to project library copies whole librar...
  • State Verified Answer
  • Subscribers 15
  • Views 5141
Copying one part to project library copies whole library
mvanderwal
mvanderwal over 3 years ago
I'm new to Capture CIS. I'm trying to copy to the LMC6482 from the OPAmp library, but when I select the part, copy, and then paste it into the project library, it copies the whole library into my project. This doesn't happen when copying things from capsym. I notice that they seem to be different files. One is a part and the other is a symbol as far as I can tell. Is there a way to copy just a single part from one library to another?
  • CadAP
    CadAP over 3 years ago +3 verified
    #Tcl Script to help to copy a part from the source library to destination library. # Please copy the tcl code to a notepad or notepad++ and save it as copy_part.tcl. #Now open Orcad Capture and go to…
  • CadAP
    +1 CadAP over 3 years ago
    #Now open Orcad Capture and go to capture command window(if command window not visible go to View-->Command Window).
    #Type in Command Window , source {<path_of_tcl_file>/copy.tcl}and press enter.
    #After sourcing the tcl code, open the destination olb, part is now available to the olb.
    #Getting the current session.
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lStatus [DboState]
    #Package/Symbol/part name that is presnet in source library and need to copy to destination library
    set partName "LMC6482"
    # puts $partName
    set partNameCS [DboTclHelper_sMakeCString $partName]
    #set the source library from which you want to copy the part
    set srcOlb [file normalize {C:\Cadence\SPB_17.4\tools\capture\library\OPAmp.olb}]
    #set the destination library where you want to paste the library
    set destOlb [file normalize {C:\Cadence\LIBRARY2.OLB}]
    set srcOlbCS [DboTclHelper_sMakeCString $srcOlb]
    set destOlbCS [DboTclHelper_sMakeCString $destOlb]
    #Get the dboLib from the source library
    set srcLib [$lSession GetLib $srcOlbCS $lStatus]
    # puts $srcLib
    #Get the Dbolib from the destination library
    set destLib [$lSession GetLib $destOlbCS $lStatus]
    #Get the package from the source library
    set pkageName [$srcLib GetPackage $partNameCS $lStatus]
    # puts $pkageName
    #Copy the package to the destination library
    set copyPkg [$destLib CopyPackageAll $pkageName $partNameCS $lStatus]
    #Mark library for save
    $lSession MarkAllLibForSave $destLib
    #Save the library
    $lSession SaveLib $destLib
    #Remove the libarary form the current session
    $lSession RemoveLib $destLib
    Hope this helps!
    • Vote Up +3 Vote Down
  • further
    0 further over 2 years ago
     The root cause of this problem is:LMC6482 have Part Aliases
    you can save OPAmp library as a temp library ,then  delete all  Aliases . and then copy LMC6482 from the OPAmp library and then paste it into the project library
