  2. Allegro X Scripting - TCL
  3. Select filter in Capture/Orcad
  • Subscribers 12
  • Views 3708
Jim OMahony
Jim OMahony over 2 years ago
I don't know if it is just me, but I find the select filter annoying. It needs to be OKed or Cancelled each time that it is used and blocks
all commands when it is on screen. So just for fun I decided to write my own version which is a floating form and does not block.
Here it is if anyone is interested.
capSelectFilterFloat_v1-0_share.zip
  • gvellet
    gvellet over 2 years ago
    Thank you, I love this tool
  • Jim OMahony
    Jim OMahony over 2 years ago in reply to gvellet
    I'm glad you like it. I add a menu pick for it which allows me to have a ctrl-f shortcut.
    The fewer menu clicks the better as far as I am concerned :-)
  • gvellet
    gvellet over 2 years ago in reply to Jim OMahony
    If I may ask, how do you add a ctlr-f shortcut to a tcl script?
    GV
  • Jim OMahony
    You have to add a menu which then lets you choose your shortcut for each menu command. Look for
    TCL Programmimg with OrCAD Capture GUI Interface
    TestMenu.zip
    in the cadence help files. If you are not familiar with menus you can put this attached file in your autoload directory and modify it as you like. As with all shared code, be careful to test everything before using on real designs...
  • gvellet
    Hi Jim,
    Your test menu script is exactly what I needed to learn how to make a user menu and make keyboard shortcut.
    Thank you very much
    GV
