  2. Allegro X Scripting - TCL
  3. I need help to write a TCL to change display property j...
  • Subscribers 13
  • Views 3685
I need help to write a TCL to change display property justification
gvellet
gvellet over 2 years ago
I need some help to write a TCL script to modify the justification (left, right, default) of display properties object such as normal text, reference designators or any other displayed property using a right mouse click menu . I searched through all the methods applicable on display property in the doc "Orcad Capture TCL/Tk Extensions". I could not find anything to change the justification . The only methods to modify the display properties that I found are: SetLocation, SetRotation, SetFont, SetColor, SetDisplayType.
Which method should I use ? If the method parameters are in a hard to understand format (for instance "logfont") can you specify the values for "left", "right" and "default" justification.
Do you have a tcl script already able to capture mouse click selection that I could easily modify to change the display property justification?
Thank you.
GV
  • CadAP
    CadAP over 2 years ago +1
    Hi Gvellet, command GetLastMouseClickPointOnPage will give the last x and y position of mouse click on the schematic canvas. I did not find direct command for modifying the justification. But you…
  • gvellet
    gvellet over 2 years ago in reply to CadAP +1
    Hi CadAP, OK I understand there is no method to edit the text justification. I will continue doing it by hand. Thank you for the research.
  • CadAP
    0 CadAP over 2 years ago
    Hi Gvellet,
    I did not find direct command for modifying the justification. But you can write a simple tcl to move left and right by taking the current position of the object and add or substract the x position to move it.
    Hope this helps
  • gvellet
    0 gvellet over 2 years ago in reply to CadAP
    Hi CadAP,
  • gvellet
    Perhaps Cadence could add a new method for text justification in the next Orcad Release
