  2. Allegro X Scripting - TCL
  3. TCL flat net export / import
  • State Suggested Answer
  • Answers 1
  • Subscribers 14
  • Views 2613
ggeorgg
ggeorgg over 2 years ago
Hi!
I am using following (similar) code to set the net color of all flat nets in my design depending on the flat net property "NET_SPACING_TYPE". I use this code to easily visualize flat nets which have a wrong value in this property.
set DboDesign [GetActivePMDesign]
set lStatus [DboState]
set CStringPropertyName [DboTclHelper_sMakeCString "Color"]
set CStringPropertyValue [DboTclHelper_sMakeCString "RGB(255,  0,  0)"]
set CStringPropertyName2 [DboTclHelper_sMakeCString "NET_SPACING_TYPE"]
set CStringPropertyValue2 [DboTclHelper_sMakeCString]
set lFlatNetsIter [$DboDesign NewFlatNetsIter $lStatus]
#get the first flat net of design
set lFlatNet [$lFlatNetsIter NextFlatNet $lStatus]
while { $lFlatNet != "NULL" } {
    puts "set lFlatNet $lFlatNet"
    $lFlatNet GetEffectivePropStringValue $CStringPropertyName2 $CStringPropertyValue2
    set EffectivePropertyValue [DboTclHelper_sGetConstCharPtr $CStringPropertyValue2]
    if { $EffectivePropertyValue eq "High_Power"} {
        # Color/Highlight the flat net
        $lFlatNet SetEffectivePropStringValue $CStringPropertyName $CStringPropertyValue
    #get the next flat net of design
delete_DboDesignFlatNetsIter $lFlatNetsIter
$lStatus -delete
Menu "View::Zoom::Redraw"
Sometimes it is working, sometimes not.
One thing I found out is, that it is normally working, if the flat nets color has been edited manually in the schematic at least once before executing this code.
Another thing I observed is, that in hierarchical designs it normally does not color the flat nets which are located on the root page, even though I know for sure the SetEffectivePropStringValue command gets execute for those flat nets as well.
I also observed, that I have to call "View::Zoom:Redraw" to directly see the changes (if it works at all).
I know the "Tools-Export Properties" menu. The flatnet colors get exported, but when changing the net color in the design and then importing the flatnets again, the color is not set back again. Why?
Does anyone have some hints why this code is not always working?
Best regards
Georg
  • CadAP
    CadAP over 2 years ago +1 suggested
    Hi Georg, I am not sure but you may try display the flat net on deign then you try your code for changing the color. Below code for displaying the faltnet. proc GetFlatNet {InstOcc wireobj } {…
  • CadAP
    0 CadAP over 2 years ago
    Hi Georg,
    #set InstOcc [GetInstanceOccurrence]
    set designobj [$InstOcc GetOwner]
    set state [DboState]
    set netobj [$wireobj GetNet $state]
    set lNetName [DboTclHelper_sMakeCString]
    $netobj GetNetName $lNetName
    #puts "Net Name:[DboTclHelper_sGetConstCharPtr $lNetName]"
    set schNet [$netobj GetSchematicNet]
    $schNet GetName $lNetName
    #puts "Schematic Net Name:[DboTclHelper_sGetConstCharPtr $lNetName]"
    set netocc [$schNet GetOccurrenceFromParent $InstOcc]
    set netoccObj [DboOccurrenceToDboNetOccurrence $netocc]
    set flatnetobj [$netoccObj GetFlatNet $state]
    set stringobj [DboTclHelper_sMakeCString]
    $flatnetobj GetName $stringobj
    #puts "Flat Net Name:[DboTclHelper_sGetConstCharPtr $stringobj]"
    $flatnetobj SetEffectivePropStringValue $CStringPropertyName $CStringPropertyValue
    return [DboTclHelper_sGetConstCharPtr $stringobj];
    proc enabler {args} {
    return true;
    proc GetCustomNetAliasDisplayName {pAlias pSchOcc pName} {
    set wire [$pAlias GetOwner]
    set pPage [$wire GetOwner]
    #puts $wire
    if {$pSchOcc == "NULL"} {
    return $pName
    return [GetFlatNet $pSchOcc $wire]
    DboTclHelper_sEvalPage $pPage
    RegisterAction _cdnGetCustomNetAliasDisplayName enabler "" GetCustomNetAliasDisplayName "";
    Hope this helps!
    Thanks.
