  2. Allegro X Scripting - TCL
  3. TCL to change Implementation Type to none for all parts...
  • State Verified Answer
  • Replies 21
  • Answers 1
  • Subscribers 15
  • Views 6533
TCL to change Implementation Type to none for all parts in a library
Jim OMahony
Jim OMahony over 1 year ago
We are experiencing the problem "QUESTION(ORCAP-1730): File is in use by other user. Want to open (library file .OLB) in ReadOnly mode?" described in the trouble shooting article
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009fyoXEAQ&pageName=ArticleContent
This article recommends changing all non hierarchical parts "Implementation Type" properties from "Schematic" to "None".
Could the  script prop_mod.tcl from troubleshooting article https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nYBdEAM&pageName=ArticleContent
be modified change this value instead of simply adding or removing properties ?
  • CadAP
    0 CadAP over 1 year ago
    Hi Jim,
    Please copy paste the below tcl code in a text editor and save as imptypepropupdate.tcl.
    Then open Orcad capture and source the tcl file and type command updateLibraryPropVal <path_of_olb>
    For example
    updateLibraryPropVal C:/Cadence/CAP.OLB , where CAP.OLB is library on which we want to update the "Implementation Type" property value to "None" for all parts/symbols.
    After running the above tcl Implementation Type property value will be changed to "None" for all packages(parts/symbol) available in the source library.
    proc updateLibraryPropVal {lLibPath} {
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lStatus [DboState]
    set lSourceOlb [file normalize $lLibPath]
    set lIndex [string last "/" $lSourceOlb]
    set lOlbName [string range $lSourceOlb [expr ($lIndex + 1) ] end ]
    set pPkgNameCString [DboTclHelper_sMakeCString]
    set pLibName [DboTclHelper_sMakeCString $lSourceOlb]
    Menu "File::Open::Library" OrSymbolEditor::TabActivate "" "" | FileDialog "OK" "$lSourceOlb" 1OrSymbolEditor::TabActivate "" ""
    set lLib [$lSession GetLib $pLibName $lStatus]
    set lPackageNameIter [$lLib NewPackageNamesIter $lStatus]
    set lStatus [$lPackageNameIter NextName $pPkgNameCString]
    set lStatusVal [$lStatus Failed]
    while {$lStatusVal != 1} {
    set pPakgName [DboTclHelper_sGetConstCharPtr $pPkgNameCString]
    # puts $pPakgName
    SelectPMItem "$pPakgName"
    MenuCommand "2147" capLaunchNewSymbolEditor "C:/CADENCE/CAP.OLB" "$pPakgName" 0 1
    OrSymbolEditor::execute setLibPartProp {[{"nm":"Implementation Type","val":"None"}]}
    # capLaunchNewSymbolEditor "$lSourceOlb" "$pPakgName" 0 1
    Menu "File::Save"
    OrSymbolEditor::TabActivate "$lSourceOlb" "$pPakgName"
    MenuCommand "57927" OrSymbolEditor::TabActivate "$lSourceOlb" "$pPakgName"
    delete_DboLibPackageNamesIter $lPackageNameIter
    SelectPMItem "./$lOlbName"
    Menu "File::Save"
    Hope this helps!
  • Jim OMahony
    0 Jim OMahony over 1 year ago in reply to CadAP
    Hi, this script works to an extent but I had to add the line
    OrSymbolEditor::execute setLibPartProp {[{"nm":"Implementation","val":""}]}
    ahead of the line
    otherwise if "Implementation" is not empty the "Implementation Type" will not change.
    The script works very slowly opening each part before changing it. That might be ok but Orcad has
    crashed twice before finishing.
    I am now wondering if there is a way to list the properties in each part in a library to see which ones have
    an" Implementation Type" of "Schematic" ? Export properties does not list this.
  • CadAP
    +1 CadAP over 1 year ago in reply to Jim OMahony
    Hi Jim,
    Thanks for your feedback.
    Please use the below tcl code to get the library part with Implementation Type <none> you can change it to "schematic" at below line
    if {$lPropValue == "<none>"}
    #provide the .OLB loaction with name.
    set libpath {C:/Cadence/LIBRARY2.OLB}
    set lLibPathCs [DboTclHelper_sMakeCString $libpath]
    set lNullObj NULL
    set lDboLibrary [DboSession_GetLib $lSession $lLibPathCs $lStatus]
    # puts $lDboLibrary
    set lPartIter [$lDboLibrary NewPartsIter $lStatus]
    set lPart [$lPartIter NextPart $lStatus]
    # puts $lsymbl
    while {$lPart!=$lNullObj} {
    set lPrpName [DboTclHelper_sMakeCString]
    set lPrpValue [DboTclHelper_sMakeCString]
    set lPrpType [DboTclHelper_sMakeDboValueType]
    set lEditable [DboTclHelper_sMakeInt]
    set lPropsIter [$lPart NewEffectivePropsIter $lStatus]
    #get the first effective property
    set lStatus [$lPropsIter NextEffectiveProp $lPrpName $lPrpValue $lPrpType $lEditable]
    while {[$lStatus OK] == 1} {
    #get the next effective property
    set lPropValue [DboTclHelper_sGetConstCharPtr $lPrpValue]
    set lPropName [DboTclHelper_sGetConstCharPtr $lPrpName]
    if {$lPropValue == "<none>"} {
    # puts $lPropName
    set pActualsymName [DboTclHelper_sMakeCString]
    $lPart GetName $pActualsymName
    puts [DboTclHelper_sGetConstCharPtr $pActualsymName]
    delete_DboEffectivePropsIter $lPropsIter
    delete_DboLibPartsIter $lPartIter
    • Vote Up +2 Vote Down
  • Jim OMahony
    The script works with the value "<none>" however neither the value "<schematic>" nor "<Schematic View>" gives any results. "<Schematic View>" is what appears in the command window when the Implementation Type is changed manually.
  • CadAP
    0 CadAP over 1 year ago in reply to Jim OMahony
    Hi Jim,
     I think here you are trying to run the above tcl code for schematic placed parts. The above  script will work if the property implementation is modified at library level, not at schematic level.
    For schematic level please use the tcl script below. It works to identify the parts which have property value. Implementation Type "Schematic View"
    set lAllParts [CapFindObjects $COrFindFilterDlg_PARTS {*}]
    foreach lPart $lAllParts {
    # puts $lPropValue
    if {$lPropValue == "Schematic View"} {
    # puts $lPropName
    Please make sure your are selecting the open  <project_name>.dsn in the capture before sourcing the tcl.
