  2. Allegro X Scripting - TCL
  3. Copy / Duplicate Pages within a .DSN in Orcad Using TCL
  • State Verified Answer
  • Replies 10
  • Subscribers 15
  • Views 8802
Henry Monro
Henry Monro over 2 years ago
set page_present no
foreach item $pages_names {
# Check if the string matches the current element
if {$item!=NULL} {
set lPageName [DboTclHelper_sMakeCString $item]
set lPage1 [$lSchematic GetPage $lPageName $lStatus]
if {$lPage == $lPage1} {
set page_present yes
if {$page_present!="no"} {
Help me Here ==>> COPY/DUPLICATE page multiple times within a same DSN with a unique name depends upon the iterations like pageabc_1, pageabc_2, pageabc3...
Thanks in Advance
  • CadAP
    CadAP over 2 years ago +1
    #Just giving an sample code how you can copy paste a selected page. You can create your own code with different page name using iteration. set dir [file dirname [info script]] set file [open "test.xml…
  • Henry Monro
    Henry Monro over 2 years ago in reply to CadAP +1
    It seems these are the capture commands for copy-pasting that you just mentioned. Isn't there a way to accomplish this using TCL commands? For instance, does a command like 'delete page' exist for copy…
  • CadAP
    CadAP over 2 years ago in reply to tennywhy +1 verified
    Hi Tennywhy, Please try below code just open a design and modify tcl for schematic name and source it. set lSession $::DboSession_s_pDboSession DboSession -this $lSession set lStatus [DboState…
  • tennywhy
    0 tennywhy over 2 years ago in reply to CadAP
    CadAP could you give me some more advice ? thanks.
  • CadAP
    +1 CadAP over 2 years ago in reply to tennywhy
    Hi Tennywhy,
    set lStatus [DboState]
    set lDesignLoc [GetSelectedPMItems]
    set ldesign [GetActivePMDesign]
    set lschiName [DboTclHelper_sMakeCString]
    set lDesignName [DboTclHelper_sMakeCString]
    set lschiNewName [DboTclHelper_sMakeCString "CadAP"]
    set lView [$ldesign GetRoot $lStatus]
    set lSchi [$ldesign GetRootSchematic $lStatus]
    set lPagecount [$lSchi GetPageCount $lStatus]
    # $lSchi GetName $lschiName
    $lSchi SetName $lschiNewName
    Menu "File::Save"
    $ldesign GetName $lDesignName
    set lDesignloc [DboTclHelper_sGetConstCharPtr $lDesignName]
    for {set i 0} {$i <$lPagecount} {incr i} {
    set lPageNewName [DboTclHelper_sMakeCString "Test$i"]
    set lDboPage [$lSchi GetPage $i $lStatus]
    # puts $lDboPage
    $lSchi Rename $lDboPage $lPageNewName
    $lSchi SavePage $lDboPage 1
    Menu "File::Save"
    Menu "File::Close"
    after 1000
    Open "$lDesignloc"
    Try and let me know your feedback.
  • tennywhy
    Thank you so much sir , that exactly was i want, it's worked perfectly,
    i need digest your code. You've done me a great favor
  • CadAP
    0 CadAP over 2 years ago in reply to tennywhy
    tennywhy  Good to hear that helped.
    Keep exploring tcl ......Slight smile
  • tennywhy
    Thank you so much, your encouragement is very important to me
