  2. Allegro X Scripting - TCL
  3. Copy / Duplicate Pages within a .DSN in Orcad Using TCL
  • State Verified Answer
  • Replies 10
  • Subscribers 15
  • Views 8801
Henry Monro
Henry Monro over 2 years ago
set page_present no
foreach item $pages_names {
# Check if the string matches the current element
if {$item!=NULL} {
set lPageName [DboTclHelper_sMakeCString $item]
set lPage1 [$lSchematic GetPage $lPageName $lStatus]
if {$lPage == $lPage1} {
set page_present yes
if {$page_present!="no"} {
Help me Here ==>> COPY/DUPLICATE page multiple times within a same DSN with a unique name depends upon the iterations like pageabc_1, pageabc_2, pageabc3...
Thanks in Advance
  • CadAP
    CadAP over 2 years ago +1
    #Just giving an sample code how you can copy paste a selected page. You can create your own code with different page name using iteration. set dir [file dirname [info script]] set file [open "test.xml…
  • Henry Monro
    Henry Monro over 2 years ago in reply to CadAP +1
    It seems these are the capture commands for copy-pasting that you just mentioned. Isn't there a way to accomplish this using TCL commands? For instance, does a command like 'delete page' exist for copy…
  • CadAP
    CadAP over 2 years ago in reply to tennywhy +1 verified
    Hi Tennywhy, Please try below code just open a design and modify tcl for schematic name and source it. set lSession $::DboSession_s_pDboSession DboSession -this $lSession set lStatus [DboState…
  • CadAP
    0 CadAP over 2 years ago
    set file [open "test.xml" a+]
    set pagenumber "10"
    set file [open "$dir/test.xml" a+]
    puts $file {<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
    <DialogControls>
    <Control Type="EDIT" Enable="TRUE" Visible="TRUE" Id="2377"> }
    puts $file "<Value><!\[CDATA\[$pagenumber\]\]></Value>"
    puts $file {</Control>
    <Control Type="PUSH_BUTTON" Enable="TRUE" Visible="TRUE" Id="1">
    <Value><![CDATA[OK]]></Value>
    </Control>
    <Control Type="PUSH_BUTTON" Enable="TRUE" Visible="TRUE" Id="2">
    <Value><![CDATA[Cancel]]></Value>
    </Control>
    </DialogControls>}
    close $file
    SelectPMItem "SCHEMATIC1/PAGE2" ; #Itertate over page and select the required page for copy.I am manually selecting page for now.
    Menu "Edit::Copy ; #Command to Copy the selected Page
    SelectPMItem "SCHEMATIC1" ;# Now select the schematic under which you want to add page.I am manually selecting schematic for now.
    #Below command will paste the copy page with page number 10
    Capture> Menu "Edit::Paste" | DialogBox "OK" "$dir/"test.xml"
    Hope this helps!
  • Henry Monro
    0 Henry Monro over 2 years ago in reply to CadAP
    It seems these are the capture commands for copy-pasting that you just mentioned. Isn't there a way to accomplish this using TCL commands? For instance, does a command like 'delete page' exist for copy pasting page, such as in set del_page [$lSchematic DeletePage $lPage] ?
  • tennywhy
    0 tennywhy over 2 years ago in reply to CadAP
    hi CadAP how can i rename schematic name and page name ? i have tried all rename command below
             DboSchematic_Rename
             CISDesign_RenameScheamtic
             CISSchematic_RenameScheamticPage
    but it dont work, could you give me some examples ? thanks
  • CadAP
    0 CadAP over 2 years ago in reply to tennywhy
    HI tennywhy,
    Tye using $pSchemticObj SetName $lSchiNewNameCString -->schematic rename and $pPageObj SetName $lPageNewNameCString-->Page rename.
  • tennywhy
    thanks sir. I did the test as you instructed, but I ran into two other issues, the first, The schematics name is not refreshed after the name is changed.,You have to reopen the file to see the new name. The second is that the rename is invalid for the page., my code as below, help me please.
    proc renameTest { } {
        set TRUE 1
        set FALSE 0
        set lStatus [DboState]
        set lNullObj ""
        set lDesign [$lSession GetActiveDesign]
        if { $lDesign == $lNullObj} {
            puts "Active design not found"]
            return
        #get schematic and rename
            set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
            set lView [$lSchematicIter NextView  $lStatus]
            set lNullObj NULL
            set i 0
            while { $lView != $lNullObj} {
                set lSchematic [DboViewToDboSchematic $lView]
                #get pages and rename
                    set lPagesIter [$lSchematic NewPagesIter $lStatus]
                    #get the first page
                    set lPage [$lPagesIter NextPage $lStatus]
                    set j 0
                    while {$lPage!=$lNullObj} {
                        #placeholder: do your processing on $lPage
                        set pgNamC [DboTclHelper_sMakeCString]
                        $lPage GetName $pgNamC
                        set pgNamS [DboTclHelper_sGetConstCharPtr $pgNamC]
                        #rename pages
                        set pgNewC [DboTclHelper_sMakeCString "pg_test$j"]
                        show "lPage $lPage $pgNamS $pgNewC"
                        # rename cant work for pages
                        $lPage SetName $pgNewC
                        incr j
                    delete_DboSchematicPagesIter $lPagesIter
                #end rename pages
                set schNewC [DboTclHelper_sMakeCString "sch_test$i"]
                # $lSchematic SetName $schNewC
                incr i
        #end rename schematics
            delete_DboLibViewsIter $lSchematicIter
        $lStatus -delete
    thanks advance
