  2. Allegro X Scripting - TCL
  3. Renaming the Offpage Connector Name Using TCL
  • State Verified Answer
  • Subscribers 14
  • Views 2390
karthikeyank
karthikeyank over 2 years ago
I have to rename the net names for selected offpage connectors. By using below attached code, it successfully renamed but in Schematic Net page it is not replacing can anyone help me out. im new to TCL.
It has to be replace like below image.
code:
namespace eval chk {} {
variable dirName [file dirname [info script]]
proc chk::chkfunc {} {
set selectedobjs [GetSelectedObjects]
set objlength [llength $selectedobjs]
set partName [DboTclHelper_sMakeCString]
set lStatus [DboState]
set lNullObj NULL
for {set i 0} {$i < $objlength} {incr i} {
set obj [lindex $selectedobjs $i]
$obj GetName $partName
set NNDt [DboTclHelper_sGetConstCharPtr $partName]
set pNameStr [DboTclHelper_sGetConstCharPtr $partName]
set pNameToReplaceWith "XXXYHHRR"
regsub -all $NNDt $pNameStr $pNameToReplaceWith pReplacedName
set pReplacedNameCStr [DboTclHelper_sMakeCString $pReplacedName]
$obj SetName $pReplacedNameCStr
set wireobj [$obj GetWire $lStatus]
set lPropNameCStr [DboTclHelper_sMakeCString "Name"]
set lPropValueCStr [DboTclHelper_sMakeCString $pReplacedName]
$wireobj SetColor $::DboValue_COLOR4
set lStatus [$wireobj SetEffectivePropStringValue $lPropNameCStr $lPropValueCStr]
chk::chkfunc
  • CadAP
    CadAP over 2 years ago +2 verified
    Hi karthikeyank, Please use the below code to name the offpage Name attribute: set lAllOffPages [CapFindObjects $COrFindFilterDlg_OFF_PAGE_CONNECTORS {*}] set lStatus [DboState] set lNullObj NULL…
  • karthikeyank
    karthikeyank over 2 years ago in reply to CadAP +1
    Thanks, that worked.
  • CadAP
    +1 CadAP over 2 years ago
    Hi karthikeyank,
    set lNullObj NULL
    set lName [DboTclHelper_sMakeCString]
    foreach offpage $lAllOffPages {
    set offpage [lindex $offpage 0]
    set lPropsIter [$offpage NewDisplayPropsIter $lStatus]
    # set lStatus [$lPropsIter NextEffectiveProp $lPrpName $lPrpValue $lPrpType $lEditable]
    set lDProp [$lPropsIter NextProp $lStatus]
    while {$lDProp !=$lNullObj } {
    $lDProp GetName $lName
    if {[DboTclHelper_sGetConstCharPtr $lName] == "Name"} {
    UnSelectAll
    set Id [$lDProp GetId $lStatus]
    # puts $Id
    SelectObjectById $Id
    SetProperty {Name} {test45} ; #set the property Name
    delete_DboDisplayPropsIter $lPropsIter
    Hope this helps!
    • Vote Up +2 Vote Down
  • karthikeyank
    0 karthikeyank over 2 years ago in reply to CadAP
