  2. Allegro X Scripting - TCL
  3. How do I get a click event on schematic in my orcal tcl...
  • State Suggested Answer
  • Answers 1
  • Subscribers 15
  • Views 3765
How do I get a click event on schematic in my orcal tcl code
Jadystone
Jadystone over 2 years ago
I want to get a click position on schematic to continue code. I write some code, But it can't work. My problem is how to implement this function
package require Tk
namespace eval {
//I want to capture the double-click event on schematic , but it can not work
    RegisterAction "OffpagePositonClick"   "::OffpageCheck::Enabler" "Double-1" "::OffpageCheck::OffpagePositonClick" "schematic"
wm withdraw .
toplevel .mywin
wm title .mywin "Modify wire Name"
wm attributes .mywin -toolwindow 1
wm attributes .mywin -topmost 1
global clicked
set clicked 0
label .mywin.label1 -text "Click anywhere in the window to continue..."
button .mywin.modifyBtn  -text "click" -command {
    global clicked
    set clicked 0
    puts "before, clicked=$clicked"
    puts "waiting mouse click"
    #waiting a click on schematic, It can not capture the mouse click event
    vwait clicked
    set lPickPosition [GetLastMouseClickPointOnPage]
    set lX  [lindex $lPickPosition 0]
    set lY  [lindex $lPickPosition 1]
    puts "Mouseclick=($lX,$lY)"
    puts "The script has continued after the mouse click."
grid .mywin.label1 -row 0 -column 0  -pady 20
grid .mywin.modifyBtn -row 1 -column 0 -pady 20
# Function to handle the mouse click event
proc handleClick {} {
    global clicked
    puts "Mouse clicked! Continuing the script..."
    set clicked 1
# Bind the left mouse button click event to the handleClick function
# this work, but it click on the window, I want clicking on schematic window
# bind .mywin <Double-1> {handleClick}
  • JuanCR
    JuanCR over 2 years ago +1
    Hi Jadystone. Allow us some time to debug this code and we'll get back to you.
  • Jadystone
    Jadystone over 2 years ago in reply to JuanCR +1
    If I can get the sch window handle, it will work. I think the bind code should be: bind $psch_window <Button-1> {handleClick} Probem is how can I get the $psch_window. Current my temporary solution…
  • CadAP
    CadAP over 2 years ago in reply to Jadystone +1
    HI Jadystone, To run call the script from schematic is to use right click option and call the function. like below: proc test1 {args} { return 1 } proc test2 {args} { puts "clicked" …
  • JuanCR
    0 JuanCR over 2 years ago
  • Jadystone
    0 Jadystone over 2 years ago in reply to JuanCR
    Current my temporary solution is replacing "vwait clicked" with
    update
    after 1000
    That can let me to get a click position on sch page. But it must click the sch window within a second. Otherwise It could get a false position that I don't want.
  • CadAP
    0 CadAP over 2 years ago in reply to Jadystone
    HI Jadystone,
    like below:
    proc test1 {args} {
    return 1
    proc test2 {args} {
    puts "clicked"
    RegisterAction "test" "test1" "" "test2" "Schematic"
    You will get option like below:
    Second one:
    Below code will call the script when you double click on the open window, it take input from schematic and process operation on the selected  schematic object.
    package require Tk
    wm withdraw .
    toplevel .mywin
    global clicked
    set clicked 0
    proc instname {} {
    set lNullObj NULL
    set namelist {}
    set selObj [GetSelectedObjects]
    if {$selObj != "lNullObj"} {
    set lName [DboTclHelper_sMakeCString]
    foreach obj $selObj {
    $obj GetName $lName
    lappend namelist "[DboTclHelper_sGetConstCharPtr $lName]"
    puts $namelist
    proc captureclick {} {
    puts "\n Mouseclick=($lX,$lY)"
    puts " \n The script has continued after the mouse click."
    instname
    bind .mywin <Double-1> {captureclick}
    Hope this help!
  • Jadystone
    0 Jadystone over 2 years ago in reply to CadAP
    Thank for your reply. My finial solution is below.
    The first method is using a delay in the code, and then click the schematic page quickly。
    update
    after 1000
    the second method is that I click the schematic a position which I expect firstly. Then click the button to continue my next action. In this method. I can get the right mouse clicked position.
    The third is placing sth such as some wires on a spare place. Then use SelectBlock to select the placed. Then cut the selection. At last paste on the schematic.
        set total [llength $wiresTobePlace]
        for {set i 0} {$i < $total } {
            set netname [lindex $wiresTobePlace $i]
            PlaceWire      $x0  $y  [expr $x0 + $PINGAP*10]  $y
            PlaceNetAlias  [expr $x0+$PINGAP] $y $netname
            set y [expr $PINGAP + $y]
        #cut the wires and then paste it at sch
        SelectBlock [expr $x0-$PINGAP] [expr 0-$PINGAP] [expr $x0+11*$PINGAP] [expr  ($total+1)*$PINGAP]  1
        Cut
    Although the first one is not a perfect solution. I like the first best. We must pay attention to click a position quickly after our action operation executing.
