  2. Allegro X Scripting - TCL
  3. Why can not get the display property of a part with tcl...
  • State Verified Answer
  • Subscribers 14
  • Views 3715
Why can not get the display property of a part with tcl script in ORCAD
Jadystone
Jadystone over 2 years ago
I want to get the name of a display property for a part. But it can't work. Why?
proc ShowDisplayProperty { } {
    set lStatus [DboState]
    set lNullObj NULL
    set lObject [GetSelectedObjects]
    set lname [DboTclHelper_sMakeCString]
    set lPropsIter [$lObject NewDisplayPropsIter $lStatus]
    #get the first display property on the object
    set lDProp [$lPropsIter NextProp $lStatus]
    while {$lDProp != $lNullObj } {
        #can not run
        $lDProp GetName $lname
        set strName [DboTclHelper_sGetConstCharPtr $lname]
        puts [format "%30s = %-30s" GetName $strName]
    delete_DboDisplayPropsIter $lPropsIter
    $lStatus -delete
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi Jadystone, The problem with your code is that once your code enters the while loop it is not getting out of it, because you are not taking the next property from the propIter. I have fixed the…
  • Jadystone
    Jadystone over 2 years ago in reply to CadAP +1
    Thank your reply. I am sorry for that My code miss the " set lDProp [$lPropsIter NextProp $lStatus]" line. The next picture is my actual code. I can get the uncomment properties (location /color /rotation…
  • CadAP
    CadAP over 2 years ago in reply to Jadystone +1 verified
    Currently, the tcl code shown in the above picture will not give the name property of the selected object. The reason is that name property is not displayed. Display Prop only works for the property…
  • CadAP
    +1 CadAP over 2 years ago
    Hi Jadystone,
    I have fixed the code by adding the line "set lDProp [$lPropsIter NextProp $lStatus]" and also added line in the code to get the property value.
    set lNullObj NULL
    set lValue [DboTclHelper_sMakeCString]
    #can not run
    $lDProp GetValueString $lValue
    set strValue [DboTclHelper_sGetConstCharPtr $lValue]
    # puts $strName
    puts [format "%30s = %-30s" GetValue $strValue]
    $lStatus -delete
  • Jadystone
    0 Jadystone over 2 years ago in reply to CadAP
    Thank your reply.  I am sorry for that My code miss the "set lDProp [$lPropsIter NextProp $lStatus]" line.
    The next picture is my actual code. I can get the uncomment properties (location /color /rotation). But can't get the name property, so I comment out from my code.
  • CadAP
    +1 CadAP over 2 years ago in reply to Jadystone
    Display Prop only works for the property displayed on the schematic canvas. If property is present on the part but not displayed, then it will not be reported.
    To get the name property of the object please add below line line set lname [DboTclHelper_sMakeCString]
    $lobject GetName $lname
    puts [DboTclHelper_sGetConstCharPtr $lname]
    Hope this helps!
  • Jadystone
    Great Thanks ! I get it.
