  2. Allegro X Scripting - TCL
  3. How can I get other parts infomation of a multi-part package...
  • State Verified Answer
  • Replies 13
  • Subscribers 16
  • Views 8130
How can I get other parts infomation of a multi-part package part with tcl script?
Jadystone
Jadystone over 2 years ago
After I select just a part (for example U2A)  of a multi-part symbol. How I use TCL script to get other parts (such as U2B/U2C....) infomations?
I want to use tcl to get all wires connected to the part pins. In other word, I want to iterate all nets on all pins for the multi-part symbol.
  • CadAP
    CadAP over 2 years ago +3 verified
    Hi Jadystone, Select the parts with multiple section and source the below code: proc dumplist {ref} { #Use current Session in Orcad_Capture set lSession $::DboSession_s_pDboSession DboSession …
  • JuanCR
    JuanCR over 2 years ago +1
    Hi Jadystone, We're looking into your query. Will get back to you ASAP.
  • tennywhy
    0 tennywhy over 2 years ago in reply to CadAP
    i cant figure it out sir, help me please. my scenario as below,
    in the design file has a mulit part package part U1, include U1A at page1,
    and U1B at page2, i have a pin number list, eg: U1.10, i want to know
    U1.10 on which page, then open the page and handle it.
    but when i try to get the U1.10's owner page (by pin ID get owner then to part,
    and then get owner, then to page, i have do the two steps correct)
    i cant get right result in PM or schematic view both. it's seem like it
    always return the first page has U1 parts, whenever the pins on which page.
    my code as below, teach me please, thanks
    set lStatus [DboState]
    set lobjs [CapFindObjects $COrFindFilterDlg_PARTS_PINS {*}]
    foreach lobj $lobjs {
    set lPrpName [DboTclHelper_sMakeCString]
    set lPrpValue [DboTclHelper_sMakeCString]
    set lPrpType [DboTclHelper_sMakeDboValueType]
    set lEditable [DboTclHelper_sMakeInt]
    # got list (inst instOCCU)
    set obj [lindex $lobj 0]
    # ignored below, right ???
    #set obj [lindex $lobj 1]
    #get pin's part
    set objPart [$obj GetOwner]
    #get part's page
    set objPage [$objPart GetOwner]
    #get page's schematic
    set objSch [$objPage GetOwner]
    set objC [DboTclHelper_sMakeCString]
    $objPart GetReference $objC
    set PartNm [DboTclHelper_sGetConstCharPtr $objC]
    $objPage GetName $objC
    set PageNm [DboTclHelper_sGetConstCharPtr $objC]
    $objSch GetName $objC
    set SCHNm [DboTclHelper_sGetConstCharPtr $objC]
    #OPEN pin's page and handle it
    OPage $objSch $PageNm
  • tennywhy
    0 tennywhy over 2 years ago in reply to tennywhy
    i have tried command "FindPins" then "GetSelectedObjects" , but it doesn't work, because i dont know which page the pin's on at the beginning
  • tennywhy
    I guess that caused by i just get the U1's DBID but not the U1A or U1B,
    but i have no idear how to get U1A or U1B's DBID
  • CadAP
    0 CadAP over 2 years ago in reply to tennywhy
    tennywhy
    Use below tcl code.
    copy and paste the below code in text file and save as .tcl. Now source the saved tcl in the capture command window.
    After sourcing type below command,  it will open the page on which U4 pin number 1 is paced and also give you page name, schematic name information in capture command window.
    OpenPageWithSelectedPin U4.1
    global lAllPins
    set lAllPins [CapFindObjects $COrFindFilterDlg_PARTS_PINS {*}]
    proc OpenPageWithSelectedPin {lRefdesPin_Number} {
    global lAllPins
    set list {}
    set lPageCS [DboTclHelper_sMakeCString]
    set lSchiCS [DboTclHelper_sMakeCString]
    set lPinNameCS [DboTclHelper_sMakeCString]
    set lPropRef [DboTclHelper_sMakeCString "Reference"]
    set lPropRefVal [DboTclHelper_sMakeCString ]
    foreach pin $lAllPins {
    $pin GetPinNumber $lPinNameCS
    set lPinNumber [DboTclHelper_sGetConstCharPtr $lPinNameCS]
    set lPartInst [$pin GetOwner]
    set lPage [$lPartInst GetOwner]
    $lPage GetName $lPageCS
    set lSchi [$lPage GetOwner]
    $lSchi GetName $lSchiCS
    $lPartInst GetEffectivePropStringValue $lPropRef $lPropRefVal
    set lPartRef [DboTclHelper_sGetConstCharPtr $lPropRefVal]
    set lPin_number "$lPartRef.$lPinNumber"
    # puts $lPin_number
    if {$lPin_number == $lRefdesPin_Number } {
    # puts "test"
    set lPageName [DboTclHelper_sGetConstCharPtr $lPageCS]
    set lSchiName [DboTclHelper_sGetConstCharPtr $lSchiCS]
    lappend list [DboTclHelper_sGetConstCharPtr $lPageCS] [DboTclHelper_sGetConstCharPtr $lSchiCS]
    OPage $lSchiName $lPageName
    puts $list
    Hope it helps to achieve your requirement.
  • tennywhy
    wow! it's get work thanks, i have a last problem, actually my design is a complicated design, it's include two or more schematic,
    every schematic has several pages, seem as
    design.dsn    schematic_1    page1
    `                    schematic_2    pg1    pg2
          when i use the command CapFindObjects $COrFindFilterDlg_PARTS_PINS {*} it's only worked the selected schematic(must select first), could i have some method make it work for whole design? or could make it work for a shematic list, by this i get schematic list first, then use the command CapFindObjects $COrFindFilterDlg_PARTS_PINS {*} for my schematic list
