  2. Allegro X Scripting - TCL
  3. How can I get other parts infomation of a multi-part package...
  • State Verified Answer
  • Replies 13
  • Subscribers 16
  • Views 8136
How can I get other parts infomation of a multi-part package part with tcl script?
Jadystone
Jadystone over 2 years ago
After I select just a part (for example U2A)  of a multi-part symbol. How I use TCL script to get other parts (such as U2B/U2C....) infomations?
I want to use tcl to get all wires connected to the part pins. In other word, I want to iterate all nets on all pins for the multi-part symbol.
  • CadAP
    CadAP over 2 years ago +3 verified
    Hi Jadystone, Select the parts with multiple section and source the below code: proc dumplist {ref} { #Use current Session in Orcad_Capture set lSession $::DboSession_s_pDboSession DboSession …
  • JuanCR
    JuanCR over 2 years ago +1
    Hi Jadystone, We're looking into your query. Will get back to you ASAP.
  • tennywhy
    0 tennywhy over 2 years ago in reply to tennywhy
    more, when i select the dsn level in PM view, the find command get nothing
  • CadAP
    0 CadAP over 2 years ago in reply to tennywhy
     tennywhy
    command "CapFindObjects $COrFindFilterDlg_PARTS_PINS {*}" is working when I select the .dsn file.
    I have multiple schematic in my design and when I select the  .\dsn from the PM and run the below command it works as expected.
    OpenPAgeWithSelectedPin U2.1 --> it opens the page of schematic2.
  • tennywhy
    0 tennywhy over 2 years ago in reply to CadAP
    thanks sir, im confuesd, i checked it again and carefully, it could open the page under root schematic when i selected the .\dsn. it's failed when Pin not on root schematic's pages,  i checked the find result list also,   it's not there. sorry, it's bothered you
