  2. Allegro X Scripting - TCL
  3. How can I get other parts infomation of a multi-part package...
  • State Verified Answer
  • Replies 13
  • Subscribers 14
  • Views 4913
How can I get other parts infomation of a multi-part package part with tcl script?
Jadystone
Jadystone over 1 year ago
After I select just a part (for example U2A)  of a multi-part symbol. How I use TCL script to get other parts (such as U2B/U2C....) infomations?
I want to use tcl to get all wires connected to the part pins. In other word, I want to iterate all nets on all pins for the multi-part symbol.
  • JuanCR
    0 JuanCR over 1 year ago
    Hi Jadystone,
    We're looking into your query. Will get back to you ASAP.
  • CadAP
    +1 CadAP over 1 year ago
    Hi Jadystone,
    Select the parts with multiple section and source the below code:
    proc dumplist {ref} {
    #Use current Session in Orcad_Capture
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lStatus [DboState]
    set lDesign [$lSession GetActiveDesign]
    set lSchi_Name [DboTclHelper_sMakeCString]
    set lPropRef [DboTclHelper_sMakeCString "Reference"]
    set lPropPRName [DboTclHelper_sMakeCString "Part Reference"]
    set lPropPRVal [DboTclHelper_sMakeCString ]
    set lPropRefVal [DboTclHelper_sMakeCString ]
    set reflist {}
    if {$lDesign != $lNullObj} {
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    #get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    set lPage_Name [DboTclHelper_sMakeCString]
    while { $lView != $lNullObj} {
    #dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    $lSchematic GetName $lSchi_Name
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    #get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    # puts [DboTclHelper_sGetConstCharPtr $lSchi_Name]
    while {$lPage!=$lNullObj} {
    #placeholder: do your processing on $lPage
    $lPage GetName $lPage_Name
    # puts [DboTclHelper_sGetConstCharPtr $lPage_Name]
    set lPartInstsIter [$lPage NewPartInstsIter $lStatus]
    #get the first part inst
    set lInst [$lPartInstsIter NextPartInst $lStatus]
    while {$lInst!=$lNullObj} {
    #dynamic cast from DboPartInst to DboPlacedInst
    set lPlacedInst [DboPartInstToDboPlacedInst $lInst]
    if {$lPlacedInst != $lNullObj} {
    $lPlacedInst GetEffectivePropStringValue $lPropRef $lPropRefVal
    $lPlacedInst GetEffectivePropStringValue $lPropPRName $lPropPRVal
    if {[DboTclHelper_sGetConstCharPtr $lPropRefVal ] == $ref && [DboTclHelper_sGetConstCharPtr $lPropPRVal] != $ref} {
    lappend reflist [DboTclHelper_sGetConstCharPtr $lPropPRVal]
    #get the next part inst
    #get the next page
    #get the next schematic view
    delete_DboLibViewsIter $lSchematicIter
    delete_DboSchematicPagesIter $lPagesIter
    return $reflist
    set selObj [GetSelectedObjects]
    set lPropRefDes [DboTclHelper_sMakeCString "Reference"]
    set lPropRefDesVal [DboTclHelper_sMakeCString ]
    foreach obj $selObj {
    $obj GetEffectivePropStringValue $lPropRefDes $lPropRefDesVal
    set lRefdes [DboTclHelper_sGetConstCharPtr $lPropRefDesVal]
    # puts $lRefdes
    puts [dumplist $lRefdes]
    Hope this helps!
    • Vote Up +3 Vote Down
  • Jadystone
    0 Jadystone over 1 year ago in reply to CadAP
    I get it. Thank you very much!
  • tennywhy
    0 tennywhy over 1 year ago in reply to Jadystone
    if have one pin number eg U1.5,
    it's belongs to a multi-part package part,eg: U1.5 at the section U1B
    how can i get the U1B's page name from U1.5 with tcl
    could you give me some advice ?
  • CadAP
    0 CadAP over 1 year ago in reply to tennywhy
    tennywhy  above tcl work for selected instance not for pin but you can modify the above tcl for getting the information when select pin .
    Tyr below suggestion to achieve your requirement,
    1. Get the selected Pin dbId (use command "GetSelectedObjects").
    2. Get the owner of the selected part (use command [GetSelectedObjects] GetOnwer). It will return the placed part instance.
    Now you have part instance you can use above tcl code to get the rest of information.
    Do let me know if still stuck.
