  2. Allegro X Scripting - TCL
  3. How to get a symbol from sch and paste it into a specified...
  • State Verified Answer
  • Subscribers 15
  • Views 3437
How to get a symbol from sch and paste it into a specified OLB library file with tcl script?
Jadystone
Jadystone over 2 years ago
I am collecting symbols from sch to enlarge my olb file. It is not a efficient way that I copy a symbol from design cache and paste it into olb file.
I want to use tcl script to do that.  How to get a symbol from sch and paste it into a specified OLB library file with tcl script?
  • CadAP
    CadAP over 2 years ago in reply to Jadystone +2 verified
    HI Jadystone, Please use below tcl code: set lSession $::DboSession_s_pDboSession DboSession -this $lSession set lStatus [DboState] set lNullObj NULL set lDesign [$lSession GetActiveDesign] set…
  • CadAP
    0 CadAP over 2 years ago
    Hi Jaydstone,
    Please use the below code to copy the cache lib to a new library.
    Make sure you have provided your library location for copy the packages.
    set lDestnLibPath [file normalize {C:\Users\Desktop\LIBRARY2.OLB}] this line need to modify according to your OLB loaction.
    set lNullObj NULL
    set lNameCString [DboTclHelper_sMakeCString ]
    set lSrcLibPathCS [DboTclHelper_sMakeCString]
    set lDesignCacheIter [$lDesign NewCachesIter $lStatus]
    set lCachedObject [$lDesignCacheIter NextCachedObject $lStatus]
    set lPartName [DboTclHelper_sMakeCString]
    #Provide the loaction of OLB in which package should be copied.
    set lDsctnLibPathCstring [DboTclHelper_sMakeCString $lDestnLibPath]
    set lDestnLib [$lSession GetLib $lDsctnLibPathCstring $lStatus]
    # set lContLib [$lCachedLibObject GetContainingLib]
    # # set llibname [$lSession GetLib $lContLib $lStatus ]
    while {$lCachedObject != $lNullObj} {
    set lCachedLibObject [DboBaseObjectToDboLibObject $lCachedObject]
    $lCachedLibObject GetSourceLibName $lSrcLibPathCS
    set lLib [$lSession GetLib $lSrcLibPathCS $lStatus]
    # puts $lLib
    if {$lLib != $lNullObj} {
    set obj1 [$lCachedObject GetName $lNameCString]
    set obj [$lLib GetPackage $lNameCString $lStatus]
    # set obj [$lContLib GetPart $lNameCString $lStatus]
    # set lGetPartName [DboTclHelper_sGetConstCharPtr $lNameCString]
    if {$obj != $lNullObj} {
    # puts $lGetPartName
    # $obj GetName $lPartName
    $lDestnLib CopyPackageAll $obj $lNameCString $lStatus
    # puts [DboTclHelper_sGetConstCharPtr $lPartName]
    # $lDestnLib MarkModified
    $lSession MarkAllLibForSave $lDestnLib
    $lSession SaveLib $lDestnLib
    $lSession RemoveLib $lDestnLib
    delete_DboDesignCachesIter $lDesignCacheIter
    Please let me your feedback how it goes at your end.
  • Jadystone
    0 Jadystone over 2 years ago in reply to CadAP
    I execute  the code. But run to the next step. It gets a NULL obj. SO it fail to continue the script.
    Capture> set obj [$lLib GetPackage $lNameCString $lStatus]
    NULL
    I am sure that the $lNameCstring is NOT null.
    Capture> set lGetName [DboTclHelper_sGetConstCharPtr $lNameCString]
    AG2KSL100C.Normal
    Capture>
    I use regexp to get the prefix name AG2KSL100C (not include .normal) and re-execute the code. It fails to get a NON-NULL obj as well.
    I think the problem is that the source  $lLib  does not exist. So it fails  at "set obj [$lLib GetPackage $lNameCString $lStatus]"
    So we can not use this method.
    I change the $lLib to $lContLib.
    it get a NULL again
  • CadAP
    +1 CadAP over 2 years ago in reply to Jadystone
    HI Jadystone,
    set lNullObj NULL
    set lDestnLibPath [file normalize {C:\Users\LIBRARY2.OLB}]
    set pkg [DboLibObjectToDboPackage $lCachedLibObject ]
    if {$pkg != $lNullObj} {
    $pkg GetName $lNameCString
    $lDestnLib CopyPackageAll $pkg $lNameCString $lStatus
    Hope this will address your issue. Please let me know feedback.
    • Vote Up +2 Vote Down
  • Jadystone
    Thank you very much. It works!
