  2. Allegro X Scripting - TCL
  3. TCL code to annotation in the Capture schematic design
  • State Verified Answer
  • Subscribers 14
  • Views 2376
RohitRohan
RohitRohan over 2 years ago
Hai Community,
Is it possible to create a TCL code for ref des annotation in the Capture schematic design.
Rohit Rohan
  • Jeet
    Jeet over 2 years ago +1
    Try using following steps: 1. Enable Journaling and Display Commands from Extended Preferences > Command Shell. 2. Now, select the design file in the project manager and select Tools > Annotate > OK…
  • Jeet
    0 Jeet over 2 years ago
    2. Now, select the design file in the project manager and select Tools > Annotate > OK.
    3. Copy the xml path from the command window and replace it in the below code in place of the below path.
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lDesign [$lSession GetActiveDesign]
    if { $lDesign != $lNullObj} {
    Menu "Tools::Annotate" | DialogBox "OK" "C:/Users/User_data/AppData/Local/Temp/CAPTURELOG/Fri_Aug_16_21_44_02_2024/Packaging_4.xml"
    SetAutomationFlag 1
    Let me know how it goes for you after performing the steps, are you able to annotate the design with TCL?
  • CadAP
    +1 CadAP over 2 years ago in reply to Jeet
    Hi Rohit,
    You can use below tcl to run the annotation in batch mode without any args:
    capBatchAnnotate
    Second the same command with args:
    capBatchAnnotate(nScope, nUpdateType, cstrCombinedProperty, additionalCombinedProperty,
    bStartAtOne, bDoNotChangePageNumber,
    bChangeInstances, bIncludeNonPrimitive,
    bPreserveDesignator, bPreserveUserEdits,
    bAnnInstExtDsgn)
    Parameters:
    nScope: int
    nUpdateType: int
    cstrCombinedProperty: char const *
    additionalCombinedProperty: char const *
    bStartAtOne: int
    bDoNotChangePageNumber: int
    bChangeInstances: int
    bIncludeNonPrimitive: int
    bPreserveDesignator: int
    bPreserveUserEdits: int
    bAnnInstExtDsgn: int
    An example with args:
    capBatchAnnotate 0 1 {{value} {Source Package}{POWER_GROUP}} {} 0 0 1 0 0 0 0
    Hope it helps!
