  2. Allegro X Scripting - TCL
  3. Add a tcl command I created/registered to the toolbar and...
  • Subscribers 13
  • Views 1877
Add a tcl command I created/registered to the toolbar and also assign an icon to it programmatically?
PatEscher
PatEscher over 2 years ago
does anyone know if it is possible to add a tcl command I created/registered to the toolbar and also assign an icon to it programmatically?
No problem to add the tcl commands as a menu (like the File menu for example)
No problem in manually adding the tcl command to the toolbar by using the customize
But as said, I want to do it programmatically, as otherwise all our users have to do it by themselves
Patrick
  • CadAP
    0 CadAP over 2 years ago
    Hi Patrick,
    Can you please explain the term programmatically here?
    What I understand is automatically loading of script for all users and users just use tcl function form menu, correct?
  • PatEscher
    0 PatEscher over 2 years ago in reply to CadAP
    we use InsertXMLMenu to add our commands into the menu bar.
    after doing this, we would like to also use tcl scripting to add the created menu items into the toolbar
    As of today I am only aware of the the interactive way in using the customize toolbar functionality
