  2. Allegro X Scripting - TCL
  3. Olb to Xml via TCL or cmd prompt
  • State Verified Answer
  • Subscribers 14
  • Views 5017
fSeyer
fSeyer over 2 years ago
is there any way to export or convert OLB into XML via windows cmd prompt or TCL script?
Thanks!
  • PatEscher
    PatEscher over 2 years ago in reply to fSeyer +1 verified
    the sample lines are above XMATIC_XML2OLB $xmlolbname $olbname XMATIC_OLB2XML $olbname $xmlolbname if you look into the OrCAD Tcl documentation in the Doc Assistant, you will find the full examples…
  • PatEscher
    0 PatEscher over 2 years ago
    there are a some samples in the tcl scripts directory and it is also mentioned in the documentation
    use XMATIC_XML2OLB $xmlolbname $olbname from XML to OLB and  XMATIC_OLB2XML $olbname $xmlolbname for the other way around
    you can put that in a script and call OrCAD with the script mode through command line
    +Patrick
  • fSeyer
    0 fSeyer over 2 years ago in reply to PatEscher
    Hi Patrick,
    Thanks, can you provide a sample line?
  • PatEscher
    +1 PatEscher over 2 years ago in reply to fSeyer
    if you look into the OrCAD Tcl documentation in the Doc Assistant, you will find the full examples incl. description
    --> SPB231/OrCAD X TCL Sample Scripts, Version-23.1/TCL Programmimg with OrCAD Capture GUI Interface
  • fSeyer
    it works, Thank You!
