  2. Allegro X Scripting - TCL
  3. Create Menu/Window with TCL to fill a user defined Title...
  • State Verified Answer
  • Replies 13
  • Subscribers 15
  • Views 16108
Create Menu/Window with TCL to fill a user defined Title block - OrCAD Capture CIS 22.2
JN202407223932
JN202407223932 over 2 years ago
Hi evereyone,
i'm completely new to TCL scripting.
I created a Title Block and added a few new properties to it. Now i would like to create a pop up window where i can set and change the values of these properties. Just like the Title Block tab in the design template view.
I already managed to create a new menu in the title bar with a script  but i don't get it how to create this pop up window.
Can someone help me with a small example maybe?
Thanks in advance.
J.
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi JN, I am sharing a sample GUI code with you, when you source the tcl it will pop window and ask user for input. Once you provide any input you will get out in the same window. Seee below screenshot…
  • tennywhy
    0 tennywhy over 1 year ago in reply to CadAP
    sir, Could you give me some advice, if you can, please teach me, I want to learn more, please!
  • CadAP
    0 CadAP over 1 year ago in reply to tennywhy
    hi tennwhy,
    Like what information you are looking in tcl space for orcad capture.
    Sure, I'll try my best to help you.
  • tennywhy
    how can i create a GUI, similar to Orcad Capture's built-in "Find And Replace Text Utility" interface,
    such as having a user input box "find what",
    a file output path and prefilled default path, eg "C:/TEST",
    two Options (eg. "A1" "B2") switched by user choose, default is "B2". and only one options can be selected
    at last have a "ACTION" button, and a "Close" button
    For me, it's enough for most situations
    could you give me some advice ?
  • CadAP
    tennywhy
    Please go to the installation folder and check the customer gui scripts using html.
    C:\Cadence\SPB_24.1\tools\capture\tclscripts\capCustomSamples
    Check the sample script and do connect in case help needed.
  • tennywhy
    thanks sir.
