  2. Allegro X Scripting - TCL
  3. Create Menu/Window with TCL to fill a user defined Title...
  • State Verified Answer
  • Replies 13
  • Subscribers 14
  • Views 15017
Create Menu/Window with TCL to fill a user defined Title block - OrCAD Capture CIS 22.2
JN202407223932
JN202407223932 over 2 years ago
Hi evereyone,
i'm completely new to TCL scripting.
I created a Title Block and added a few new properties to it. Now i would like to create a pop up window where i can set and change the values of these properties. Just like the Title Block tab in the design template view.
I already managed to create a new menu in the title bar with a script  but i don't get it how to create this pop up window.
Can someone help me with a small example maybe?
Thanks in advance.
J.
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi JN, I am sharing a sample GUI code with you, when you source the tcl it will pop window and ask user for input. Once you provide any input you will get out in the same window. Seee below screenshot…
  • tennywhy
    0 tennywhy over 1 year ago in reply to CadAP
    CadAP sir, could you tell me what tool you used to create the html form? Or what table creation tool is more suitable for Tcl language? thanks
  • CadAP
    0 CadAP over 1 year ago in reply to tennywhy
    Hi Tennywhy,
    I want to understand here "what do you mean by suitable tool for tcl language?"
    I use notepad++ or Visual studio code to write tcl script or html .
  • tennywhy
    What I mean is what kind of visual tool can quickly generate HTML forms for tcl? For example, tkinter can quickly generate forms, but it can only be called by python, not tcl. I thought you used some good tools to create this kind of form. Do you mean that it is all done by manually writing HTML code? I don't know how you completed this step. In addition, can you tell me what functions the orPrmWebComp package has, or where I can see the instructions? Thank you
