  2. Allegro X Scripting - TCL
  3. TCL script to read OLB library file and generate list of...
  • State Verified Answer
  • Replies 12
  • Subscribers 14
  • Views 7983
TCL script to read OLB library file and generate list of the symbols into text file
fSeyer
fSeyer over 2 years ago
Hi
is it possible to make TCL script that will read each OLB library file and generate a list of the symbols (just the name of symbol) into a text files?
thank you
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi Fseyer, Please use below code make sure below is set before sourcing the below code. After sourcing the code file Symbol.txt will create at library location. set dirName {C:/Users/Downloads…
  • fSeyer
    0 fSeyer over 2 years ago in reply to CadAP
    Hi CadAP,
    here's the code, not sure if i doing wrong. Thanks
    set dirName {C:/SPB_Data/Capture_Lib} ; # provide your library location.
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lStatus [DboState]
    set lNullObj NULL
    namespace eval readOlb {} {
    # variable dir [file normalize [info script]]
    # variable dirName [file dirname $dir]
    catch { variable fileData [glob -directory $dirName *.olb] } filereaderror
    set lSymbollist {}
    set lFile [open "$readOlb::dirName/Symbol.txt" a+]
    foreach olb $readOlb::fileData {
    puts $lFile $olb
    set libname [DboTclHelper_sMakeCString $olb]
    set lDboLibrary [DboSession_GetLib $lSession $libname $lStatus]
    set lib1 [$lDboLibrary GetContainingLib]
    set partName [DboTclHelper_sMakeCString ]
    set pkgIter [$lDboLibrary NewPackagesIter $lStatus]
    set pPkg [$pkgIter NextPackage $lStatus]
    set lNullObj NULL
    while {$pPkg!=$lNullObj} {
    $pPkg GetName $partName
    # puts "partName : [DboTclHelper_sGetConstCharPtr $partName]"
    puts $lFile "PartName : [DboTclHelper_sGetConstCharPtr $partName]"
    # puts $lDboLibrary
    delete_DboLibPackagesIter $pkgIter
    close $lFile
    $lSession RemoveLib $lDboLibrary
  • fSeyer
    0 fSeyer over 2 years ago in reply to fSeyer
    Hi CadAP,
    after restarting the capture the code works fine.
    maybe i just typed the wrong way earlier.
    code gives output i want.
    Thank you the Help!
  • CadAP
    0 CadAP over 2 years ago in reply to fSeyer
    HI Fseyer,
    I see you have added below variable at two place:
    set dirName {C:/SPB_Data/Capture_Lib} ; # provide your library location. --> Please remove this one, I have added just for your example.
    set dirName {C:/SPB_Data/Capture_Lib} ;#--> This one is correct (defined under namespace.). Do not remove.
  • fSeyer
    Hi CadAP,
    yes i removed the example variable and restart my capture then it works fine.
    thank you
  • fSeyer
    Hi CadAP,
    sorry i got one more thing to ask, how can i run this code standalone?
    without opening the capture, can run directly into windows cmd prompt?
    my main goal is to incorporate with the allegro skill lisp so i was thinking running TCL into batchscript.
