  2. Allegro X Scripting - TCL
  3. TCL script to read OLB library file and generate list of...
  • State Verified Answer
  • Replies 12
  • Subscribers 14
  • Views 7989
TCL script to read OLB library file and generate list of the symbols into text file
fSeyer
fSeyer over 2 years ago
Hi
is it possible to make TCL script that will read each OLB library file and generate a list of the symbols (just the name of symbol) into a text files?
thank you
  • CadAP
    CadAP over 2 years ago +1 verified
    Hi Fseyer, Please use below code make sure below is set before sourcing the below code. After sourcing the code file Symbol.txt will create at library location. set dirName {C:/Users/Downloads…
  • CadAP
    0 CadAP over 2 years ago in reply to fSeyer
    HI fSeyer.
    Please go to the below link getting information about ruuning tcl from window command prompt.
    Article (20471611) Title: How to execute Capture Tcl script (.captcl file) from Windows command line
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • fSeyer
    0 fSeyer over 2 years ago in reply to CadAP
    Hi CadAP,
    thanks for the Link, unfortunately i can't access the portal for now, my license host-id maintenance still on progress of renewal.
    i will check once already renewed.
