  2. Allegro X Scripting - TCL
  3. TCL script to read OLB library file and generate list of...
  • State Verified Answer
  • Replies 12
  • Subscribers 12
  • Views 3537
TCL script to read OLB library file and generate list of the symbols into text file
fSeyer
fSeyer over 1 year ago
Hi
is it possible to make TCL script that will read each OLB library file and generate a list of the symbols (just the name of symbol) into a text files?
thank you
  • CadAP
    +1 CadAP over 1 year ago
    Hi Fseyer,
    Please use below code make sure below is set before sourcing the below code.
    After sourcing the code file Symbol.txt will create at library location.
    set dirName {C:/Users/Downloads/lib_doc} ; # provide your library location.
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lStatus [DboState]
    set lNullObj NULL
    namespace eval readOlb {} {
    # variable dir [file normalize [info script]]
    # variable dirName [file dirname $dir]
    catch { variable fileData [glob -directory $dirName *.olb] } filereaderror
    set lSymbollist {}
    set lFile [open "$readOlb::dirName/Symbol.txt" a+]
    foreach olb $readOlb::fileData {
    puts $lFile $olb
    set libname [DboTclHelper_sMakeCString $olb]
    set lDboLibrary [DboSession_GetLib $lSession $libname $lStatus]
    set lib1 [$lDboLibrary GetContainingLib]
    set partName [DboTclHelper_sMakeCString ]
    set pkgIter [$lDboLibrary NewPackagesIter $lStatus]
    set pPkg [$pkgIter NextPackage $lStatus]
    set lNullObj NULL
    while {$pPkg!=$lNullObj} {
    $pPkg GetName $partName
    # puts "partName : [DboTclHelper_sGetConstCharPtr $partName]"
    puts $lFile "PartName : [DboTclHelper_sGetConstCharPtr $partName]"
    # puts $lDboLibrary
    delete_DboLibPackagesIter $pkgIter
    close $lFile
    $lSession RemoveLib $lDboLibrary
    Hope this helps
  • fSeyer
    0 fSeyer 11 months ago in reply to CadAP
    Hi CadAP
    Thank you for the reply.
    i'm not sure but i getting a return of can't read "readOlb::dirName": no such variable
  • CadAP
    0 CadAP 11 months ago in reply to fSeyer
    Hi Fseyer,
    Can you please let me know how you are ruining the above code and also share the screen shot from command promt.?
  • fSeyer
    Hi CadAP
    i just copied the code and save as "Olb_exportTxt.tcl"
    set dirName to directory to where my .olb files
    then type in capture cmd window > source {C:/SPB_Data/TCL/Olb_exportTxt.tcl}
  • CadAP
    Hi FSeyer,
    Please share the tcl code you are using, My end same code working fine.
