  2. Allegro X Scripting - TCL
  3. Get level of hierarchy of part
  • State Verified Answer
  • Subscribers 15
  • Views 3550
ElecDesinger
ElecDesinger over 2 years ago
I am using Example 3.2.28.2 Iterate over instance occurrence hierarchy as base for my TCL script. How can I check if a part is on main level or inside hierarchy? My design has multi-level hierarchy.
  • CadAP
    CadAP over 2 years ago in reply to ElecDesinger +2 verified
    Hi ElecDesigner, I have created a sample script which will print the part hierarchy level with root schematic as well as schematic under which part is placed. Steps to run: 1. Copy the code in…
  • CadAP
    0 CadAP over 2 years ago
    Hi ElecDesigner,
    I think you can try the below suggestion
    1. Iterate over each page .
    2. run below command on the page, if $error is 1 the parts are from block and if error is "Menu command not found" then parts are on top.
    catch {Menu "View::Ascend Hierarchy"} error1
     puts $error1
    3. if error ==1 then dump the parts else ignore it.
    Please do let me know your feedback.
  • ElecDesinger
    0 ElecDesinger over 2 years ago in reply to CadAP
    Hi CadAP, this command did not help. It only tells me if the selected part can be descended or not. I am looking for a command that tells me which level of hierarchy a part is located.
    Main level: Hierarchy = 0
    Inside one Hierarchal block: Hierarchy = 1
    Inside two Hierarchal blocks: Hierarchy = 2
    etc.
  • CadAP
    +1 CadAP over 2 years ago in reply to ElecDesinger
    Hi ElecDesigner,
    Steps to run:
    1. Copy the code in notepad and save with .tcl extension.
    2. Select a part and source the code.
    set lPartNameCs [DboTclHelper_sMakeCString]
    set lSchiNameCs [DboTclHelper_sMakeCString]
    set lPropNameCs [DboTclHelper_sMakeCString "Part Reference"]
    set lPropValueCs [DboTclHelper_sMakeCString]
    set lSelectedObj [GetSelectedObjects]
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lStatus [DboState]
    set lLib [$lSelectedObj GetContainingLib]
    set lPage [$lSelectedObj GetOwner]
    set lSchi [$lPage GetOwner]
    $lSchi GetName $lSchiNameCs
    $lSelectedObj GetEffectivePropStringValue $lPropNameCs $lPropValueCs
    # $ob GetName $lPartNameCs
    set lPropValue [DboTclHelper_sGetConstCharPtr $lPropValueCs]
    set lPartName [DboTclHelper_sGetConstCharPtr $lPartNameCs]
    set lSchiName [DboTclHelper_sGetConstCharPtr $lSchiNameCs]
    set lPrpName [DboTclHelper_sMakeCString "Root View"]
    set lPrpValue [DboTclHelper_sMakeCString]
    $lLib GetEffectivePropStringValue $lPrpName $lPrpValue
    set lcounter 0
    set lRootSchi [DboTclHelper_sGetConstCharPtr $lPrpValue]
    puts [DboTclHelper_sGetConstCharPtr $lPrpValue]
    if {$lRootSchi != $lSchiName} {
    # incr lcounter
    while {$error1 == 1} {
    incr lcounter
    puts "Refdes $lPropValue is palced on Schmetic $lSchiName\(Root_SchiName:= $lRootSchi\) at hierachy level $lcounter "
    • Vote Up +2 Vote Down
  • ElecDesinger
    Thanks, this gives the hierarchy level of selected part.
  • invincibleTechi
    0 invincibleTechi over 2 years ago in reply to CadAP
    CadAP  Thanks for providing a sample code for getting hierarchy level of selected part.
    Keep up the good work!!!!
