  2. Allegro X Scripting - TCL
  3. More information about enum type variable in TCL Class
  • State Verified Answer
  • Subscribers 12
  • Views 1610
Morgan
Morgan 9 months ago
Hi Friends of the community,
I will use one TCL class which have a enum type variable DboBaseObject::ObjectTypeT, but I can't find more information about it on the document  TCL/Tk Extensions.
Can you proviod more information about enum type variable like this, and What arguments should be passed to the TCl class? How I can use this?
  • CadAP
    0 CadAP 9 months ago
    Morgan
    When you select a part and type below command you will get nType.
    [GetSelectedObject] GetObjectType --> return nType (13 ) PLACED_INSTANCE
    if you type puts $DboBaseObject_PLACED_INSTANCE returns 13.
    Now you can select wire or other schematic object and get the nType value.
    Hope it helps.
  • Morgan
    0 Morgan 9 months ago in reply to CadAP
    Hi CadAP,
    I mean one TCL class such as GetCachedSymbol or ReplaceCache, the varible "type: enum DboBaseObject::ObjectTypeT" or "nObjType: enum DboBaseObject::ObjectTypeT", What arguments should be passed to it? How to define the arguments and Where to query?
    GetCachedSymbol(SourceLibName, SourceSymbolName, type) : returns DboSymbol
    Class : DboLib(DboBaseObject):
    Parameters:
    SourceLibName: CString &
    SourceSymbolName: CString &
    UpdateCache(sourceLibName, sourceObjName, nObjType) : returns DboState
    Parameters:
    sourceLibName: CString &
    sourceObjName: CString &
  • Morgan
    Hi CadAP,
    Your command maybe wrong, when I select one part, and tpye command [GetSelectedObject] GetObjectType, it return [    1]invalid command name "GetSelectedObject", when I type command  [GetSelectedObjects] GetObjectType, it return 13, but not "nType (13 ) PLACED_INSTANCE"
    When I type command "puts $DboBaseObject_PLACED_INSTANCE", it really print 13.
    But, How I know should use variable "$DboBaseObject_PLACED_INSTANCE" if that command dosen't return "nType (13 ) PLACED_INSTANCE" ?
  • CadAP
    +1 CadAP 9 months ago in reply to Morgan
    Morgan
    Correct syntax is GetSelectedObjects.
    In place of DboBaseObject::ObjectTypeT variable you can provide nType 13 for placed instance, 65  "TITLEBLOCK_INSTANCE"  15 PORT_INSTANCE etc.
    Ans: From design cache container if you want to filter only placed instance (all components) you need to pass value 13 in place ofDboBaseObject_PLACED_INSTANCE,  or 65 for TITLEBLOCK_INSTANCE etc.
  • Morgan
    Thanks CadAP.
