  2. Allegro X Scripting - TCL
  3. How to make display the value of property automatically...
  • State Verified Answer
  • Subscribers 14
  • Views 3096
How to make display the value of property automatically?
Morgan
Morgan over 1 year ago
Hi friends of the community,
Now have an isssue about Page
  • CadAP
    CadAP over 1 year ago in reply to Morgan +1 verified
    Hi Morgan, Please find the below code. Copy pastes the code and place in capture autoload folder. Once you open the capture script will be loaded and when you open a desing will see that Revcode…
  • CadAP
    0 CadAP over 1 year ago
    Hi Morgan,
    Please check the below article it will help you to achieve your requirement with little modification.:
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009m3A9EAI&pageName=ArticleContent
    Please do let me know in case of any issue.
  • Morgan
    0 Morgan over 1 year ago in reply to CadAP
    Hi CadAP,
    Can you help me post the content of the article here, I can't open it.
    Thanks.
  • CadAP
    +1 CadAP over 1 year ago in reply to Morgan
    Hi Morgan,
    Once you open the capture script will be loaded and when you open a desing will see that Revcode value is displayed with the with name Cadance.
    You can modify the code to just display the property value not to change it.
    proc TitlePropSetEnabler {args} {
    return 1
    proc testpage {args} {
    # global i
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lNullObj NULL
    set lStatus [DboState]
    set lDesign [$lSession GetActiveDesign]
    set lSchi_Name [DboTclHelper_sMakeCString]
    set lTitleProp [DboTclHelper_sMakeCString "RevCode"]
    # set lTitlePropVal [DboTclHelper_sMakeCString]
    set lTitlePropVal [DboTclHelper_sMakeCString "Cadence"]
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    #get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    set lPage_Name [DboTclHelper_sMakeCString]
    while { $lView != $lNullObj} {
    #dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    $lSchematic GetName $lSchi_Name
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    #get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    # puts [DboTclHelper_sGetConstCharPtr $lSchi_Name]
    while {$lPage!=$lNullObj} {
    #placeholder: do your processing on $lPage
    $lPage GetName $lPage_Name
    # puts [DboTclHelper_sGetConstCharPtr $lPage_Name]
    # lappend pagelist [DboTclHelper_sGetConstCharPtr $lPage_Name]
    set lTitleBlocksIter [$lPage NewTitleBlocksIter $lStatus]
    #get the first title block set
    set lTitle [$lTitleBlocksIter NextTitleBlock $lStatus]
    while {$lTitle!=$lNullObj} {
    #placeholder: do your processing on $lTitle
    #get the next title block set
    # set lStatus [$lTitle GetEffectivePropStringValue $lTitleProp $lTitlePropVal]
    set lStatus [$lTitle SetEffectivePropStringValue $lTitleProp $lTitlePropVal]
    # puts [DboTclHelper_sGetConstCharPtr $lTitlePropVal]
    # puts [$lStatus OK]
    delete_DboPageTitleBlocksIter $lTitleBlocksIter
    # #get the next page
    #placeholder: do your processing on $lSchematic
    #puts $lSchematic
    #get the next schematic view
    delete_DboLibViewsIter $lSchematicIter
    delete_DboSchematicPagesIter $lPagesIter
    RegisterAction "_cdnOrNotifyDesignOpened" "TitlePropSetEnabler" "" "testpage" ""
  • Morgan
    Hi CadAP,
    thank you
  • CadAP
    0 CadAP over 1 year ago in reply to Morgan
    Hi Moragn,
    I have a suggestion here that you can read the value from the .xml file that create when you set the value from Option-->Design Template-->Tile Block.
    I hope it helps to achieve your requirement.
