  2. Allegro X Scripting - TCL
  3. TCL foreach command encryption issue?
  • Subscribers 14
  • Views 2114
palemoon
palemoon over 1 year ago
I am tryping to encrypt my TCL project for OrCAD with  tclcompiler86.exe by following the method described in help documents.
I found it seems to have some bug in OrCAD TCL environment excuting the encrypted .tbc file with foreach command inside a proc.
Here is the simple example:
a.tcl:
 foreach i {a b c d e} {
puts "puts eng $i"
b.tcl:
proc abc {} {
  puts "puts eng $i"
I encrypted tcl files with the command:
tclcompiler86 .\a.tcl to get a.tbc
tclcompiler86 .\b.tcl to get b.tbc
Then source it in Orcad command window, a.tbc and b.tcl runs okay, but b.tbc failed.
the same b.tbc can runs okay in tclsh:
Both 17.4 and 24.1 version has same situation, does anyone know how to fix it? Or any other encryption method for TCL projects?
  • CadAP
    0 CadAP over 1 year ago
    Hi Palemonn,
    Which tcl encryption you are using?
    Can you attach  b.tbc file here, so that I can check it.
  • palemoon
    0 palemoon over 1 year ago in reply to CadAP
    I use tclcompiler86.exe from TCLDevKit 5.4.0 to build .tbc files.
    Here are the test files (a.tcl, a.tbc, b.tcl, b.tbc)
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/138/testFiles.zip
