  2. Allegro X Scripting - TCL
  3. How to get pin position and location?
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 15
  • Views 6508
Morgan
Morgan over 1 year ago
Hi friends of the community,
After select one Symbol on Page with Capture CIS, How to get all pin position(Top, Bottom, Left, Right), and pin location (X,Y) to place wire, use TCL?
  • CadAP
    CadAP over 1 year ago in reply to CadAP +1 suggested
    Morgan Please find below code for getting pin position(Left, Right, Top, Bottom): proc lGetPinPos {lPin} { set lStatus [DboState] set lPinName [DboTclHelper_sMakeCString] $lPin GetPinName $lPinName…
  • CadAP
    0 CadAP over 1 year ago
    Hi Morgan,
    Below api will help you to get X and Y position of hotspot where we connect wire.
    Once you have hotspot of pin use that coordinate to draw wire using first point (x,y ) of pin hotspot.
    DboPortInst_sGetHotSpotX(obj, status) : returns int
    Parameters:
    obj: DboBaseObject *
    status: DboState &
    DboPortInst_sGetHotSpotY(obj, status) : returns int
    Parameters:
    status: DboState &
    Hope it helps.
  • Morgan
    0 Morgan over 1 year ago in reply to CadAP
    Thank you, CadAP, Now the question becomes:
    1. What value should be give to variable obj?
    2. How to get pin position on the Symbol, such as Top, Bottom, Left or Right?
  • CadAP
    0 CadAP over 1 year ago in reply to Morgan
    Hi Morgan,
    Ans: Pin dbid. you can get the pin dbid and pass that as argument to the above api.
    Ans: Why you need pin position any specific reason, because i don't see any direct api for it.
  • Morgan
    Hi CadAP,
    1.When I use code: $portInst GetId $lStatus, get the pin ID, and pass it to DboPortInst_sGetHotSpotX, it error;
    2.Get pin position to place wire, if the pin is on Top, the wire will go to top from pin hotspot; if the pin is on right, the wire will go to right from pin hotspot, so must know the pin position on the Symbol.
  • CadAP
    Hi Morgan,
    Ans: DboPortInst_sGetHotSpotX $portInst $lStatus -- correct command.
    Ans: Need to create a script to get pin position. I'll create a sample and share it with you.
