  2. Allegro X Scripting - TCL
  3. Modify properties based on REFDES with ASC
  • State Verified Answer
  • Subscribers 14
  • Views 2188
Gelzone
Gelzone over 1 year ago
I have found a command in the document that can modify property - modifyProp.
It seems that it can modify properties by select a component or just modify all by the scope parameter.
I would like to know if there is any way to modify properties when given REFDEF? (e.g. given "R1", I can modify its PART_NUMBER)
  • CadAP
    CadAP over 1 year ago +2 verified
    Gelzone You can create a tcl proc which can be used to work when refed value is given. for example, proc userpropmodify {refded} { #Get value of refdes from schematic If {$ refded ==…
  • CadAP
    +1 CadAP over 1 year ago
    Gelzone
    for example,
    If {$refded == {Value taken form schematic}} {
    modifyprop -name -value
    Please check our ASK portal to get articles related to this query.
    Hope it helps
    • Vote Up +2 Vote Down
  • Gelzone
    0 Gelzone over 1 year ago in reply to CadAP
    I have found what I need in the Cadence ASK. Thanks!
