  2. Allegro X Scripting - TCL
  3. The GetOccurrencesCount function (Orcad Capture CIS 16.6...
  • State Verified Answer
  • Subscribers 15
  • Views 2040
The GetOccurrencesCount function (Orcad Capture CIS 16.6) behaves abnormally when run in a standalone Tcl shell
LL202411014740
LL202411014740 over 1 year ago
HELP!!!!
When using OrCAD Capture CIS in Cadence 16.6, I encountered an issue where obtaining the Occ from the schematic Inst was ineffective:
  •  Directly entering the following command in the OrCAD Capture CIS command window returns the Occ count correctly:
```TCL
set lSession $::DboSession_s_pDboSession
DboSession -this $lSession
set lDesign [GetActivePMDesign]
set lStatus [DboState]
set pSchematicName "T1"
set lSchematicName [DboTclHelper_sMakeCString $pSchematicName]
set lSchematic [$lDesign GetSchematic $lSchematicName $lStatus]
$lSchematic GetOccurrencesCount
# this code return 2
  • Invoking the same command in the Tcl shell returns null.
```TCL
C:\Cadence\SPB_16.6\tools\tcltk\8.4\bin\wish.exe
load {C:\Cadence\SPB_16.6\tools\capture\orDb_Dll_Tcl.dll} DboTclWriteBasic
set lSession [DboTclHelper_sCreateSession]
set pDesignPath {D:\work\orcad Tcl\DESIGN1.DSN}
set lDesignPath [DboTclHelper_sMakeCString $pDesignPath]
set lDesign [$lSession GetDesignAndSchematics $lDesignPath $lStatus]
# this code return 0
DboTclHelper_sSetDboObjectInProcess $lDesign
  • LL202411014740
    LL202411014740 over 1 year ago +1 verified
    The issue also occurs when using set lSession [DboTclHelper_sCreateSession] in OrCAD's Command Window to generate lSession . However, it works properly with the following commands: set lSession $ ::DboSession_s_pDboSession…
  • LL202411014740
    +1 LL202411014740 over 1 year ago
    The issue also occurs when using set lSession [DboTclHelper_sCreateSession] in OrCAD's Command Window to generate lSession. However, it works properly with the following commands:
