  2. Allegro X Scripting - TCL
  3. How to use ReplaceCache ?
  • State Verified Answer
  • Subscribers 14
  • Views 4527
BT202504251050
BT202504251050 over 1 year ago
I am working on a Tcl script to automate the process of replacing a .OLB file via File Explorer → Design Cache → Replace Cache.
proc read_ini : Utlize to fetch the .olb path at Capture.ini [ Capture.ini => Part Library Directories => Dir0 ]
proc showCacheEntries:Change Part Library path
My question is why the ReplaceCache has no effect? [ Version : 17.2.0]
ReplaceCache(OldPackageOrSymbolName, OldLibName, NewName, NewLibName, bUpdateCache = 0, bPreserverefDes = 0)
proc showCacheEntries { pDesign } {
set lCacheNameCStr [DboTclHelper_sMakeCString]
set lCacheLibNameCStr [DboTclHelper_sMakeCString]
set lStatus [DboState]
set lCacheObjectsIter [$pDesign NewCachesIter $lStatus $::IterDefs_ALL]
set lCachedObject [$lCacheObjectsIter NextCachedObject $lStatus]
# Get Capture.ini to fetch location
set root [pwd]
set input [GetProductVersion]
if {[regexp {(\d+\.\d+)-\d+} $input match version]} {
puts "Version: $version"
} else {
puts "Version not found."
set lLibLocation [read_ini "$root/cdssetup/OrCAD_Capture/${version}.0/capture.ini" "Part Library Directories" "Dir0"]
set lLibLocation [string toupper $lLibLocation]
puts $lLibLocation
while { $lCachedObject!= "NULL" } {
set lCachedLibObject [DboBaseObjectToDboLibObject $lCachedObject]
$lCachedObject GetName $lCacheNameCStr
$pDesign GetSourceLibName $lCacheNameCStr $lCachedLibObject $lCacheLibNameCStr
# Get Design Cache Library Name
set lKey [DboTclHelper_sGetConstCharPtr $lCacheNameCStr]
set lLibrary [DboTclHelper_sGetConstCharPtr $lCacheLibNameCStr]
set lPartNameCStr [DboTclHelper_sMakeCString $lKey]
regexp {[^\\]+$} $lLibrary match
regexp {[^.]+$} $match extension
set NewLibrary "$lLibLocation$match"
set lNewLibNameCStr [DboTclHelper_sMakeCString $NewLibrary]
# Update Library Location
if {$extension == "OLB" && $lLibrary != $NewLibrary} {
puts "### UPDATE ### $lKey : $lLibrary -> $NewLibrary"
# ReplaceCache(OldPackageOrSymbolName, OldLibName, NewName, NewLibName, bUpdateCache = 0, bPreserverefDes = 0)
$pDesign ReplaceCache $lPartNameCStr $lCacheLibNameCStr $lPartNameCStr $lNewLibNameCStr 1 0
delete_DboDesignCachesIter $lCacheObjectsIter
$lStatus -delete
  • CadAP
    CadAP over 1 year ago in reply to BT202504251050 +1 verified
    BT202504251050 Please check the below article on the ASK portal: Article (20512519) Title: How to update the design cache library path to a new library path URL: https://support.cadence.com/apex…
  • CadAP
    0 CadAP over 1 year ago
    BT202504251050
    What is the class of "pDesign" you are passing it here?
  • BT202504251050
    0 BT202504251050 over 1 year ago in reply to CadAP
    proc capShowCacheData { pDesignName } {
        set lSession [DboTclHelper_sCreateSession]
        set lDesignNameCStr [DboTclHelper_sMakeCString $pDesignName]
        set lDesign [$lSession GetDesignAndSchematics $lDesignNameCStr $lStatus]
        if { "NULL" != $lDesign} {
        puts "$pDesignName is open"
        showCacheEntries $lDesign
        $lSession RemoveLib $lDesign
        } else {
        puts "$pDesignName could not open"
        DboTclHelper_sDeleteSession $lSession
        $lStatus -delete
    set lDesignName [DboTclHelper_sMakeCString]
    set lDesign [GetActivePMDesign]
    $lDesign GetName $lDesignName
    set lDesignCacheFile [open $::capGenerateDesignCache::mOutDesignCacheFile w]
    capShowCacheData $lDesignName
  • CadAP
    0 CadAP over 1 year ago in reply to BT202504251050
    BT202504251050
    ReplaceCache works for class DboLib and in your code you are passing DboDesign which is incorrect. Please get the dbolib from cache and pass it as args to ReplaceCache.
  • BT202504251050
    Hi CadAP,
    I’ve been trying to use commands related to returns dbolib as described in OrCAD_Capture_TclTk_Extensions.pdf, but they seem to have no effect.
    Here's a snippet of my code for reference:
            # set lLib [$lSession GetOpenLib $lCacheLibNameCStr $lStatus]          <---- ERROR (It seems return DboBaseObject, rather than Dbolib )
            # set lLib [$lSession GetLib $lCacheLibNameCStr $lStatus]              <---- ERROR (It seems return DboBaseObject, rather than Dbolib )
            # set lLib [$lSession GetLibAndSchematics $lCacheLibNameCStr $lStatus] <---- ERROR (It seems return DboBaseObject, rather than Dbolib )
            # set lLib [$pDesign GetContainingLib]                                 <---- NO ERROR (Not work)
            $lLib ReplaceCache $lPartNameCStr $lCacheLibNameCStr $lPartNameCStr $lNewLibNameCStr 1 0
    Would you be able to provide a example on how to correctly obtain a DboLib object?
    Thanks for your support!
  • CadAP
    +1 CadAP over 1 year ago in reply to BT202504251050
    BT202504251050
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009mMUXEA2
    This will help to answer your query.
