  2. Allegro X Scripting - TCL
  3. How to load Orcad DB DLL in TCL
  • State Suggested Answer
  • Answers 1
  • Subscribers 12
  • Views 1242
cineboxandrew
cineboxandrew 6 months ago
Im attempting to do some automation tooling to export a design database xml and pdf from a dsn file.
Im following the instructions in "C:\Cadence\SPB_24.1\tools\capture\tclscripts\OrCAD_Capture_TclTk_Extensions.pdf", however the dll it says to load on page 44 doesn’t exist. I tried loading ‘orDb_Dll64.dll’ but it crashed the interpreter with exit code 0xC0000005. This happened both in IronTCL x64 8.6 and with tkinter. How do I access the orcad database from a TCL interpreter? Alternatively is there a better way of doing what Im attempting to do?
I tried calling Capture directly with a TCL script, but that fails if capture is already open
  • CadAP
    0 CadAP 6 months ago
    cineboxandrew
    You can try below command:
    <cadence_installtionLocation\tools\bin>capture.exe  <tclfilelocation\test.tcl>
    In tcl script you can open a design and then close once tcl operation completed.
