  2. Allegro X Scripting - TCL
  3. Getting all the values showing in "Name" property dropd...
  • State Verified Answer
  • Subscribers 15
  • Views 3698
Getting all the values showing in "Name" property dropdown
karthikeyank
karthikeyank over 1 year ago
I'm trying to get the selected wire names that showing in property by using my below program I can be able to return only one name, instead I want to return all the names in dropdown.
is that possible? if yes please guide me to get the output.
Current output:
DPS25F
Expected output:
DPS25F,DPS25S,1__6__VDD_LT__PWR
Program:
SetOptionBool Journaling True
namespace eval chk {} {
variable dirName [file dirname [info script]]
proc chk::chkfunc {} {
set lNullObj NULL
set lStatus [DboState]
set lAllWire [GetSelectedObjects]
set name [DboTclHelper_sMakeCString]
foreach lObject $lAllWire {
set lPage [$lObject GetOwner]
set lNet [$lObject GetNet $lStatus]
set lschNet [$lNet GetSchematicNet]
set lPropsIter [$lschNet NewEffectivePropsIter $lStatus]
set lPrpName [DboTclHelper_sMakeCString]
set lPrpValue [DboTclHelper_sMakeCString]
set lPrpType [DboTclHelper_sMakeDboValueType]
set lEditable [DboTclHelper_sMakeInt]
set lStatus [$lPropsIter NextEffectiveProp $lPrpName $lPrpValue $lPrpType $lEditable]
while {[$lStatus OK] == 1} {
set NetFilt [DboTclHelper_sGetConstCharPtr $lPrpName]
if {$NetFilt == "Name" } {
set Name [DboTclHelper_sGetConstCharPtr $lPrpName]
set Value [DboTclHelper_sGetConstCharPtr $lPrpValue]
puts $Value
delete_DboEffectivePropsIter $lPropsIter
DboTclHelper_sEvalPage $lPage
chk::chkfunc
  • CadAP
    CadAP over 1 year ago in reply to karthikeyank +1 verified
    karthikeyank Updated code for getting alias and schematic net in list and dump the list in command Capture command window. set lStatus [DboState] set lnet [GetSelectedObjects] set lSchnet [[$lnet…
  • karthikeyank
    karthikeyank over 1 year ago in reply to CadAP +1
    Thanks for the support it worked well.
  • CadAP
    0 CadAP over 1 year ago
    karthikeyank
    Please try the below code and let me know how it goes:
    Select a net and source the code it will dump all schematic name of selected net
    set lSchnet [[$lnet GetNet $lStatus ] GetSchematicNet]
    # set lschi [[$lnet GetOwner] GetOwner]
    set schilist {}
    set lname [DboTclHelper_sMakeCString]
    set schiter [$lSchnet NewNetsIter $lStatus]
    set lschinet [$schiter NextNet $lStatus]
    while {$lschinet != "NULL"} {
    $lschinet GetNetName $lname
    set schiname [DboTclHelper_sGetConstCharPtr $lname]
    if {[lsearch $schilist $schiname] == -1} {
    lappend schilist $schiname
    puts $schilist
  • karthikeyank
    0 karthikeyank over 1 year ago in reply to CadAP
    Thanks for the reply, by using above program I can be able to return schematic net names. I want to get net alias name as well can you help me with that.
    Now im getting this:
    DPS25S DPS25F
    Expected Ouput:
    DPS25S DPS25F 1__6__VDD_LT__PWR
  • CadAP
    +1 CadAP over 1 year ago in reply to karthikeyank
    karthikeyank
    set schilist {}
    set lAliasNameCString [DboTclHelper_sMakeCString]
    set lAliasIter [$lnet NewAliasesIter $lStatus]
    #get the first alias of wire
    set lAlias [$lAliasIter NextAlias $lStatus]
    while { $lAlias!="NULL"} {
    #placeholder: do your processing on $lAlias
    #get the next alias of wire
    $lAlias GetName $lAliasNameCString
    set lAliasName [DboTclHelper_sGetConstCharPtr $lAliasNameCString]
    # NewNetsIter
    delete_DboWireAliasesIter $lAliasIter
    # delete_DboSchematicNetsIter $schiter
    puts $schilist
  • karthikeyank
  • KD202502275710
    0 KD202502275710 over 1 year ago in reply to CadAP
    Genious
