  2. Allegro X Scripting - TCL
  3. Design Rules Check OPTION FROM TCL
  • State Suggested Answer
  • Answers 1
  • Subscribers 14
  • Views 2050
ZH202409115233
ZH202409115233 over 1 year ago
I want to use a TCL script to trigger changes to the DRC configuration, to avoid having to reconfigure DRC every time I switch DSNs. Originally, I tried using the following code:
 Menu "PCB::Design Rules Check" | DialogBox  "OK" "C:/Users/ZHANGH~1/AppData/Local/Temp/CAPTURELOG/Fri_Jul_25_16_27_33_2025/Undo Warning!!_1.xml"
However, after executing it, only the UI interface appeared, and I was still missing the DRC configuration information. Do you have any suggestions on how I can achieve my goal?
  • TechnoBobby
    0 TechnoBobby over 1 year ago
    Hi ZH202409115233 ,
    You can achieve this using below steps:
    1. First, enable logging mode by running following commands in command window:
    orPrmAutomation::setMode 1
    orPrmAutomation::setPath {C:/temp/drc.log}
    2. Then open the DRC UI from PCB > Design Rules Check, configure the required rules, and click Run. This will generate a drc.log file at the above path. i.e. {C:/temp/drc.log}
    3. To reuse the configuration in any dsn, use:
    orPrmAutomation::setMode 2
    Menu "PCB::Design Rules Check" | DialogBox "OK" "C:%temp%/CAPTURELOG/<Folder_name_with_day_date>/Undo Warning!!_1.xml"
    Make sure the paths to drc.log and the XML file are valid and correctly updated.
    Hope this helps!
