  2. Allegro X Scripting - TCL
  3. Function iterator optimization
  • State Verified Answer
  • Subscribers 14
  • Views 4866
ZH202409115233
ZH202409115233 over 1 year ago
I have implemented a function designed to assign properties to specific components according to predefined rules. However, during execution, the memory usage continuously increases, eventually leading to a software crash. Could you please advise on potential optimization strategies?
code ;
proc parts_NCHandle_event_handle_dsn {} {
    set lStatus [DboState]
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lDesign [$lSession GetActiveDesign]
    set NULL_OBJ "NULL"
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    while {[set lView [$lSchematicIter NextView $lStatus]] != $NULL_OBJ} {
        set lSchematic [DboViewToDboSchematic $lView]
        puts $lSchematic
        set lPagesIter [$lSchematic NewPagesIter $lStatus]
        while {[set lPage [$lPagesIter NextPage $lStatus]] != $NULL_OBJ} {
            puts $lPage
            set lPartInstsIter [$lPage NewPartInstsIter $lStatus]
            while {[set lInst [$lPartInstsIter NextPartInst $lStatus]] != $NULL_OBJ} {
                set lPlacedInst [DboPartInstToDboPlacedInst $lInst]
                if {$lPlacedInst != $NULL_OBJ} {
                    if {[catch {
                        setNC $lPlacedInst
                    } err]} {
                        puts " $lPlacedInst : $err"
            delete_DboPagePartInstsIter $lPartInstsIter
            DboTclHelper_sEvalPage $lPage
        delete_DboSchematicPagesIter $lPagesIter
    puts "执行完成"
    delete_DboLibViewsIter $lSchematicIter
    $lStatus -delete
proc setNC {lPlacedInst} {
set lNullObj NULL
# puts $lcolor
set lPropNameCStr [DboTclHelper_sMakeCString "Value"]
#DboDisplayProp
set pDispProp [$lPlacedInst GetDisplayProp $lPropNameCStr $lStatus]
# puts $pDispProp
if {$pDispProp != $lNullObj} {
set lvalue [DboTclHelper_sMakeCString]
set lStatus [$pDispProp GetValueString $lvalue]
set lvStr [DboTclHelper_sGetConstCharPtr $lvalue]
DboTclHelper_sDeleteCString $lvalue
# puts $lvStr
set str ""
if {![string match "NC/*" $lvStr ] } {
# puts ookk11
set lcolor [$lPlacedInst GetColor $lStatus]
if {$lcolor == 45} {
set str "NC/"
} elseif {$lcolor == 43} {
set str "NC/NC/"
if {$str != ""} {
# puts $str$lvStr
set lPropValueCStr [DboTclHelper_sMakeCString $str$lvStr]
set lStatus [$lPlacedInst SetEffectivePropStringValue $lPropNameCStr $lPropValueCStr 0]
set lPropsIter [$lPlacedInst NewDisplayPropsIter $lStatus]
#set lNullObj NULL
#puts 1
#DboDisplayProp
DboTclHelper_sDeleteCString $lPropNameCStr
if {$pDispProp != $lNullObj } {
if {![regexp {^NC/[^N]} $lvStr]} {
return
if {![string match "NC/NC/*" $lvStr ]} {
return
#puts $lvalue
#get the first display property on the object
set lDProp [$lPropsIter NextProp $lStatus]
while {$lDProp !=$lNullObj } {
set lPropNameCStr [DboTclHelper_sMakeCString "Color"]
if {[regexp {^NC/[^N]} $lvStr]} {
set lPropValueCStr [DboTclHelper_sMakeCString "RGB(192,192,192)"]
set lStatus1 [$lPlacedInst SetEffectivePropStringValue $lPropNameCStr $lPropValueCStr]
$lDProp SetColor 45
if {[string match "NC/NC/*" $lvStr ]} {
set lPropValueCStr [DboTclHelper_sMakeCString "RGB(128,128,128)"]
$lDProp SetColor 43
#get the next display property on the object
delete_DboDisplayPropsIter $lPropsIter
$lStatus -delete
puts "done"
  • TechnoBobby
    TechnoBobby over 1 year ago +1 verified
    Hi ZH202409115233 , Are you monitoring memory usage in Task Manager and noticing it gradually rise to 100%, after which the tool crashes? Also, does the same script run fine on a smaller design? If yes…
  • TechnoBobby
    +1 TechnoBobby over 1 year ago
    Hi ZH202409115233 ,
    If yes, one thing you could try is disabling online DRC while running the script. You can do this by going to:
    PCB > Design Rules Check > Options, and turning off online DRC.
    Hope this helps!
  • ZH202409115233
    0 ZH202409115233 over 1 year ago in reply to TechnoBobby
    Thank you, your suggestion is effective. Sorry I didn't provide complete information earlier. The smaller design is runnable. I intentionally used a very large design (33 pages) to test it, and I observed in Task Manager the process of memory gradually increasing, until it reached 100%, after which the application crashed.
  • PatEscher
    0 PatEscher over 1 year ago in reply to TechnoBobby
    TechnoBobby CadAP
    is there a possibility to turn off the online DRC through a tcl command
    We also do quite some operations on the design and would like to turn it off before and then afterwards turn it on again
  • TechnoBobby
    0 TechnoBobby over 1 year ago in reply to PatEscher
    Hi PatEscher ,
    Yes, there is a TCL command to turn online DRC on or off.
    Below link will take you to an article on ASK:
    Title: How can I enable or disable 'Online DRC' by using Tcl commands?
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009mKF5EAM
    Hope this helps!
  • PatEscher
    Hello TechnoBobby ,
    Thanks, that works fine but it requires that the global DRC setting is activated.
    Now, if this global DRC setting is not activated, how can i set/toggle the design specific settings?
    Alternatively, would it be possible to turn the global DRC settings on on demand and also turn it off?
