  2. Allegro X Scripting - TCL
  3. Design Template Option For TCL
  • State Suggested Answer
  • Answers 1
  • Subscribers 15
  • Views 2133
ZH202409115233
ZH202409115233 over 1 year ago
I want to modify the "Fonts" option in the design template using TCL language, but the XML file I obtained from the command does not support my modifications. What should I do?
How can I retrieve the font configuration from the configuration file and flexibly set it using TCL language?
command window:
Menu "Options::Design Template" | DialogBox  "OK" "C:/Users/ZHANGH~1/AppData/Local/Temp/CAPTURELOG/Mon_Aug__4_17_51_44_2025/Fonts_8.xml"
  • TechnoBobby
    TechnoBobby over 1 year ago +1 suggested
    Hi ZH202409115233 , The Design Template defines default settings for newly created designs & schematic pages and its settings are stored in Capture.ini file. These settings can be modified using TCL by…
  • TechnoBobby
    0 TechnoBobby over 1 year ago
    Hi ZH202409115233 ,
    The Design Template defines default settings for newly created designs & schematic pages and its settings are stored in Capture.ini file. These settings can be modified using TCL by writing directly to the [Design Template] section.
    You can use the GetIniPath command to get the path of the currently loaded .ini file.
    And following TCL commands to modify & load changes:
    writeProfileString {Design Template} {Property..........} {[-9, 5, 0, 0, 400, 0, 0, 0, 0, 3, 2, 1, 34, Bahnschrift Condensed]}
    COrCapIniLoader_loadINI {Path_to_capture.ini}
    These values follow the MFC font structure with attributes like nHeight, nWeight, bItalic, lpszFacename, etc. Full reference:
    https://learn.microsoft.com/en-us/cpp/mfc/reference/cfont-class
    Hope this helps!
  • Morgan
    0 Morgan over 1 year ago in reply to TechnoBobby
    Hi  TechnoBobby,
    Is there any way to modify the font of command window?
    Thank you.
