  2. Allegro X Scripting - TCL
  3. Use Tcl command to "Generate BOM" with ASC
  • State Verified Answer
  • Subscribers 14
  • Views 3983
Gelzone
Gelzone over 1 year ago
Recently I try to use invokeBomHDL command to generate BOM but it just show the dialog box and not generate the BOM.
If I manually use: Tools -> Generate BOM -> Generate, it works well.
I have used similar way to generate BOM in the OrCAD (e.g. Menu "Tools::Bill of Materials" | DialogBox "OK" "~/Bill_of_Materials.xml") before and it worked well.
I wonder that if there is any way to generate BOM with tcl in ASC?
  • CadAP
    CadAP over 1 year ago +1
    Gelzone Below is a sample tcl script to generate hdl bom using tcl from ASC. # Sample script to genarte bom set projectpath [ file dirname [pwd]] set projectcpm [ cps::getProjectCPM ] set projectcpm…
  • CadAP
    CadAP over 1 year ago in reply to Gelzone +1 verified
    Gelzone Please use updated code, for reportFormat variable we have to select option from a list [ TEXT HTML SS ], I used csv which is not a correct args. Now I have passed the correct args. …
  • CadAP
    0 CadAP over 1 year ago
    Gelzone
    set projectcpm [ cps::getProjectMainCPM ]
    set projectDir [ cps::getProjectMainDir ]
    set projectName [ sch::dbGetRootDesignName ]
    set template "C:/Cadence/SPB_24.1/share/cdssetup/template.bom" ; #chnage if your using different PSB version.
    set delimeter {,}
    set reportFormat "CSV"
    set variantFile "variant.dat"
    set varinatCompare {}
    set varaintName {}
    puts $projectDir
    if {$reportFormat eq "HTML"} {
    set outfile "[file join $projectDir "output" $projectName]/bom/BOM.html"
    } else {set outfile "$projectDir/output/$projectName/bom/BOM.csv"}
    if {$varaintName != "NULL" || $varaintName != "" } {
    exec bomhdl.exe -proj $projectcpm -nographic -t $template -f $reportFormat -delim $delimeter -o $outfile -a NO -var $variantFile $varaintName
    if {$varaintName == "NULL" || $varaintName == ""} {
    Please try and let me know your feedback.
  • Gelzone
    0 Gelzone over 1 year ago in reply to CadAP
    CadAP
    Thanks it worked.
    But there is a little bug that if I first open the "Generate BOM" window and select the output format as HTML and close, and then I use your code to get the BOM (I will get a csv format if I don't change your code) which is a .csv extension but has a HTML content.
    Process: (Manually) Tools -> Generate BOM -> Report Format select HTML -> Close -> Run your code in the command window -> Get a .csv extension BOM but with HTML content
    ASC Ver. 23.1 S006
    Can you help me to figure it out?
    BTW if I change back to Spreadsheet Format manually, the output file get the correct result.
  • CadAP
    +1 CadAP over 1 year ago in reply to Gelzone
    Gelzone
    Please use updated code, for reportFormat variable we have to select option from a list [ TEXT HTML SS], I used csv which is not a correct args.
    # bomhdl.exe -proj <Project_File_Name> [-nographic] [-t <Template_File_Name>] [-f HTML | SS|TEXT] [-delim <delimeter>] [-o <outfile name>] [-a YES | NO] [-var <Variant_Database> [variant1 variant2...] [COMPARE] [ALL]]
    #Command to generate Bom with inputs.
    # set projectcpm [ cps::getProjectCPM ]
    # set project [file join $projectpath $projectcpm]
    # set projectName [string range $projectcpm 0 [expr [string last "." $projectcpm] - 1]]
    # puts "projectpath: = [join "$projectpath" "ouput" "$projectName" "/"] "
    # puts "projectcpm: =$projectcpm"
    # puts "projectName: =$project"
    # puts "projectName: =$projectName"
    set delimeter {,}
    set reportFormat "SS" ;#report value [TEXT][HTML][SS]
    set varaintName {}
    # puts $projectDir
  • Gelzone
    CadAP
    It got the right result thanks.
    I wonder how to find such information associated with ASC but not show in the "C:\Cadence\SPB_23.1\doc\scap_tcl_comms\scap_tcl_commsTOC.html"?
    I found the commands related to HDL but unfortunately I have not used it before.
