  2. Allegro X Scripting - TCL
  3. Building a editor , because we all need this
  • Subscribers 14
  • Views 2717
Mhawley1
Mhawley1 over 1 year ago
Hey Everybody , I feel like we need and or Deserve a build in editor inside of Cadence .
So here is my code so far and it collapses the procedures . Feel free to use this as a starting point . My goal is to execute the code . Highlighting would be nice . Autocompletion would be probably not be possible . But try it out everyone and see what you think .
package require Tk
proc LaunchWindow {} {
set w .myWin
catch {destroy $w}
toplevel $w
wm withdraw .
wm title $w "Text Box with Scrollbar"
label $w.label -text "Enter your text below:"
frame $w.textFrame
text $w.textbox -width 50 -height 10 -wrap word -yscrollcommand "$w.scroll set"
scrollbar $w.scroll -orient vertical -command "$w.textbox yview"
pack $w.textbox -side left -fill both -expand 1
pack $w.scroll -side right -fill y
pack $w.label -padx 10 -pady 5
pack $w.textFrame -padx 10 -pady 5 -fill both -expand 1
# Button to print text
button $w.button -text "Execute" -command {
puts [.myWin.textbox get 1.0 end]
pack $w.button -padx 10 -pady 5
# Define a tag that hides text
$w.textbox tag configure hidden -elide true
# Button to hide all blocks enclosed in { ... }
button $w.hideBlocksButton -text "Hide Code Blocks" -command {
set text [.myWin.textbox get 1.0 end]
set startIdx 0
set braceLevel 0
set blockStart ""
# Scan character by character
for {set i 0} {$i < [string length $text]} {incr i} {
set char [string index $text $i]
set idx [.myWin.textbox index "1.0 + $i chars"]
if {$char eq "\{"} {
if {$braceLevel == 0} {
set blockStart $idx
incr braceLevel
} elseif {$char eq "\}"} {
if {$braceLevel > 0} {
incr braceLevel -1
set nextCharIndex [expr {$i + 1}]
set blockEnd [.myWin.textbox index "1.0 + $nextCharIndex chars"]
.myWin.textbox tag add hidden $blockStart $blockEnd
pack $w.hideBlocksButton -padx 10 -pady 5
# Button to restore all blocks enclosed in { ... }
button $w.restoreBlocksButton -text "Restore Code Blocks" -command {
set startIdx 0
set braceLevel 0
set blockStart ""
set blockStart $idx
incr braceLevel
incr braceLevel -1
.myWin.textbox tag remove hidden $blockStart $blockEnd
pack $w.restoreBlocksButton -padx 10 -pady 5
LaunchWindow
  • PatEscher
    PatEscher over 1 year ago
    we need an Editor for what? For writing tcl code for OrCAD?
    Why does an editor like notepad++ with syntax highlighting is not sufficient. Or why not even using one of the free IDE's instead which bring syntax highlighting, check and some auto completion?
    +Patrick
  • Mhawley1
    Mhawley1 over 1 year ago in reply to PatEscher
    Because I dont want have to save the notepad file and then load it ( or write some iterator script that scans for it )  . I want it to run now at the click of a button . I want a editor to come up right inside of Cadence and be there real time to test out snippets . And the company I work at is paranoid as heck so I cant just install an IDE. Im going to stick with this and see where it goes . Might be useful to someone .
  • Mhawley1
    Here is a update on the editor in TCL . It now supports basic folding of procedures and there is a find search . Its not a very pretty but it suits my needs .
    Commenting # has some problems where it only assesses every other line and when you run the find it retains the highlight .
    anyways below is the link the the GitHub repo . Feel free to clone or add or commit to .
    github.com/.../Cadence_tcl_editor.git
