  2. Allegro X Scripting - TCL
  3. ERROR(ORCAP-1028) The Spice COM Wrapper error has occur...
  • State Suggested Answer
  • Answers 1
  • Subscribers 14
  • Views 2529
ERROR(ORCAP-1028) The Spice COM Wrapper error has occurred
JO202509059437
JO202509059437 over 1 year ago
The above error occurred when running the following script command in OrCAD X Capture 24.1:
Menu "File::Open::Project" | FileDialog  "OK" "orcad_file.opj" 1 | MessageBox "OK"
It worked fine in the previous version of OrCAD 16.5.
When I try to open a project "orcad_file.opj" via the OrCAD menu, the project opens successfully.
The project contains only a schematic, it does not contain any PSpice model.
  • TechnoBobby
    TechnoBobby over 1 year ago +1 suggested
    Hi JO202509059437 , Could you please try either of the following: • Use the complete path of the .opj file in the FileDialog command. example: Menu "File::Open::Project" | FileDialog "OK" "C:/Users/orcad_file…
  • TechnoBobby
    0 TechnoBobby over 1 year ago
    Hi JO202509059437 ,
    example: Menu "File::Open::Project" | FileDialog  "OK" "C:/Users/orcad_file.opj" 1 | MessageBox "OK"
    • Or, use the direct command:
    Open "C:/Users/orcad_file.opj"
    Hope this helps!
  • JO202509059437
    0 JO202509059437 over 1 year ago in reply to TechnoBobby
    Thank you very much for your answer.
    Both methods work.
