  2. Allegro X Scripting - TCL
  3. Hide the window after using command "exportNetList" in ...
  • Subscribers 14
  • Views 2084
Hide the window after using command "exportNetList" in ASC
Gelzone
Gelzone over 1 year ago
I call exportNetList not only by manually but also with tcl script, and it will show a message window to tell me where the netlist saved.
Can I hide the window or any way to close the window automatically?
BTW, can I change the output path for the netlist file? I found it always generated at <//output/sch_name/packaged/>.
  • CadAP
    0 CadAP over 1 year ago
    Gelzone
    cps::setSuppressDialog 1
    This will suppress all the pop up messages for current session. Executing same command with value 0 will re-enable pop up messages:
    cps::setSuppressDialog 0
    Try and let me know your inputs
  • Gelzone
    0 Gelzone over 1 year ago in reply to CadAP
    I used the .cpm file as my input and it worked when I used exportNetList command.
    But when I tried another related command such as exportPhysical, it seems the procedure did not work normally (it just generated pstcmdb.dat, not the pstdedb.cdsz). I ensured that I got the complete compressed file if I copy and paste the command manually.
    But it's not my primary problem. It's enough the cps::setSuppressDialog 1 can work on exportNetList.
