  2. Allegro X Scripting - TCL
  3. Replace a component using its CDS_LIBRARY_ID in system ...
  • State Suggested Answer
  • Answers 1
  • Subscribers 14
  • Views 1861
Replace a component using its CDS_LIBRARY_ID in system Capture
YC202504163531
YC202504163531 over 1 year ago
[In System Capture 24.1]
I’m trying to write a script that replaces a component with its EMPTY counterpart and vice versa. The challenge is that, to successfully replace the component and keep it in sync with Pulse, I need the CDS_LIBRARY_ID property of the new component. I don’t know where to extract this property from. I can get the value from an already placed component, but that’s not useful for replacements.
I’m using this command:
replace -part -by $componentLibs -preserveUserProp -preserveRefDes -propVisChanged -key [list {MATERIAL=EMPTY=1} {CDS_LIBRARY_ID=$cdsLibId=0} ] -i [list  {}] -useexistingtr  -cpath [list  "$cpath" ]
sch::leaveBatchMode
I tried to get the CDS_LIBRARY_ID property from the part table of the library, but it’s not there. I suspect this property is injected by the Part Information Manager. Does anyone know more about this, or how to automate the Part Information Manager window to retrieve or set this property?
  • CadAP
    CadAP over 1 year ago +1 suggested
    YC202504163531 CDS_LIBRARY_ID=classlib:RE i see is join string of lib and cell. User below api to get the lib cell and join the string with ':' sch::dbGetLibCellView [getSel] Hope it helps…
  • CadAP
    0 CadAP over 1 year ago
    YC202504163531
    Hope it helps.
