  2. Allegro X Scripting - TCL
  3. lock net alias
  • State Suggested Answer
  • Answers 1
  • Subscribers 14
  • Views 3847
lock net alias
tennywhy
tennywhy over 1 year ago
could anybody knows how to lock net alias on pages, Currently, the orcad capture built-in lock command has no effect on net alias.  could i lock net alias through Tcl code?  help me please.
  • CadAP
    CadAP over 1 year ago +1 suggested
    tennywhy , Tyr the below tcl api: DboTclHelper_sLockProperty(pObj, propName, lockFlag, preTrigger, postTrigger) Parameters: pObj: DboBaseObject * propName: CString lockFlag: int preTrigger: char…
  • CadAP
    0 CadAP over 1 year ago
    tennywhy ,
    Parameters:
    propName: CString
    lockFlag: int
    preTrigger: char *
    postTrigger: char *
    Let me know if it helps or not
  • tennywhy
    0 tennywhy over 1 year ago in reply to CadAP
    hi sir, i have no idear how to use this API,  my code as below, but it desnt work, could you help me check it ?
    suppose i have a wire on page, net alias as uart_tx,  and select the net alias then run the code below.
    set lSelObjsL [GetSelectedObjects]
    set LengthlSelObjsL [llength $lSelObjsL]
    if { $LengthlSelObjsL != 0 } {
        set netAlias_type 49
        foreach lObject $lSelObjsL {
            set lObjType [DboBaseObject_GetObjectType $lObject]
            # net alias type =49
            if { $lObjType == $netAlias_type } {
                DboTclHelper_sLockProperty $lObject "Name" 1 "" ""
  • tennywhy
    sir, could you help me check my code  or give me some tips about the last two parameters ?  appreciated.
