  2. Allegro X Scripting - TCL
  3. How to always open the first schematic page when using ...
  • Subscribers 14
  • Views 1659
How to always open the first schematic page when using "openProject" to open a .cpm file?
Gelzone
Gelzone over 1 year ago
As title, I found sometimes I opened a project with command openProject, it would open the page I had modified last time.
Most of the time it will open the first page (and that's what I want), so I'd like to ask that is there any way to "reset" the status of the project or just force the openProject to open the first page only?
  • CadAP
    0 CadAP over 1 year ago
    Gelzone
    I've had multiple attempts but wasn't able to reproduce the behavior you mentioned.
    However, I think there might be an alternative solution:
    you can register a tcl command that opens the first page of a design, which will be triggered whenever someone opens the project.
  • Gelzone
    0 Gelzone over 1 year ago in reply to CadAP
    Yes, I can check which page is open using such as cps::getSPathByTabIndex and decide to close it or keep doing the task. I just wonder if there is any function I can call.
    BTW, the process I have done is: open a page -> modify a properties of a component (e.g. modifyProp -name PART_NUMBER -value "ttt1") -> save -> do not close the page and directly close the ASC (Allegro PCB Venture 23.1 S006 (4217799) 7/18/2024 64-bit) -> reopen ASC and the project then it will open the modified page
