  2. Allegro X Scripting - TCL
  3. Any way to "Global Modify" a property of a component with...
  • State Verified Answer
  • Subscribers 14
  • Views 2833
Any way to "Global Modify" a property of a component with tcl in ASC?
Gelzone
Gelzone over 1 year ago
I wrote a procedure to modify a property (e.g. PART_NUMBER) of a component (type: INST) page by page.
I met a issue that if a component is associated with different pages, then it will raise violation error.
Error message:
PKG1104 Physical part <PART_NAME>_<PACK_TYPE>-<VALUE>,<PART_NUMBER> cannot be assigned to package <modified_component_refdes>.
The package <modified_component_refdes> is associated with part name <PART_NAME>_<PACK_TYPE>-<VALUE>,<PART_NUMBER>-<JEDEC_TYPE>.
I guess the error occurs that I didn't modify all components (w/ same refdes) simultaneously.
And here is my code snippet, maybe there is something I can improve:
proc testMod {} {
# Read refdes & cpn mapping
puts "Processing mapping list..."
set refPropsFile "C:/temp/refdes_props.csv"
ReadFiles create readRefProps $refPropsFile "csv"  # This is just a class I created to read csv file
set refPropsList [readRefProps readFile "\t"]   # Return type is a list
set mapping {}
foreach eachMapping $refPropsList {
# Extract the key and value from the sublist
dict set mapping [lindex $eachMapping 0] [lrange $eachMapping 1 end]
readRefProps destroy
puts "Updating Properties..."
# Loading the schPageUtils pacakge.
package require schPageUtils
# Getting All Page Information.
set pageListDict [schPageUtils::getDesignPagesAllInfo]
# Reading Total Number of Pages
set size [schPageUtils::getPagesInfoSize $pageListDict]
set pageIter 1
while {$pageIter <= $size} {
set currTabSPath [cps::getSPathByTabIndex 1]
puts $pageIter
puts $currTabSPath
set pageId [sch::dbGetActivePage]
selectObject all
set selItem [sch::dbGetSelectedItems $pageId]
selectObject none
#set hasModified 0
foreach item $selItem {
set itemType [sch::dbGetType $item]
if {$itemType == $::sch::DBTInst} {
set ItemSpath [sch::dbGetSPath $item]
array set RefOrg [join [sch::dbxGetRefDesAndOriginFromInstSpath $ItemSpath]]
set location $RefOrg(refdes)
if {[dict exists $mapping $location]} {
#set hasModified 1
set props [dict get $mapping $location]
set pn [lindex $props 0]
set footprint [lindex $props 1]
puts $location
puts $pn
puts $footprint
sch::dbSelectObjectById $item $::sch::DBTrue
modifyProp -name PART_NUMBER -value $pn
modifyProp -name JEDEC_TYPE -value $footprint
puts "Properties modified."
saveAll
sch::nextPage
closeItem $currTabSPath
incr pageIter
puts "Done"
#saveAll
#sch::closeProject
#exit
  • CadAP
    CadAP over 1 year ago in reply to Gelzone +1 verified
    Gelzone I found one issue that after selecting component by db id and making property changes you are not deselect the previous component. It was still selected and current one is also selected which…
  • Gelzone
    0 Gelzone over 1 year ago
    And there is another weird behavior while the procedure is running.
    For instance, if the process is modifying a component (e.g. at p.36), then the action should be: modify PART_NUMBER & JEDEC_TYPE -> save -> close the page -> open p.37.
    But the real scenario is: close p.36 -> open p.37 & p.36 again!
    So the following process will always open p.36, not the real page I want.
    I am not sure it's the side effect of the condition I mentioned in the article or it's a new problem. I need some help.
  • CadAP
    0 CadAP over 1 year ago in reply to Gelzone
    Gelzone
    Try the below modified code and let me know your feedback:
    proc testMod {} {
    sch::enterBatchMode
    set mapping {}
    set pageIter 1
    set lViewid [schPageUtils::getPageId $pageListDict $pageIter]
    # set currTabSPath [cps::getSPathByTabIndex 1]
    openItem $lViewid SCH PAGE
    puts $pageIter
    # puts $currTabSPath
    selectObject all
    selectObject none
    #set hasModified 0
    #set hasModified 1
    puts $location
    puts $pn
    puts $footprint
    saveAll
    # sch::nextPage
    closeItem $lViewid
    incr pageIter
    puts "Done"
    sch::leaveBatchMode
    #saveAll
    #sch::closeProject
    #exit
  • Gelzone
    0 Gelzone over 1 year ago in reply to CadAP
    CadAP
    Thanks for help but unfortunately, the weird behavior (open previous page) I mentioned still exists.
    BTW, I noticed that sch::enterBatchMode makes the process faster.
    The primary objective is to modify the properties and I thought the associated issue is the root cause for the weird behavior but I am wrong.
    After several experiments (of course using your code), I found the selItem variables are totally the same for the p.36 & p.37, and I also check the pageId for the p.36 & p.37, they are different.
    So the scenario is p.36 & p.37 have different pageId but with the same selItem! (maybe the selectObject all didn't work or ...?)
    P.S. Why this so strange is that the p.35 is modified perfectly and open the p.36 without any issue.
  • CadAP
    +1 CadAP over 1 year ago in reply to Gelzone
    Gelzone
    I found one issue that after selecting component by db id and making property changes you are not deselect the previous component. It was still selected and current one is also selected which makes issue.
    I tired and able to get the get correct refdes form each page at my end.
    proc testMod {} {
    sch::enterBatchMode
    set mapping {}
    set pageIter 1
    puts $pageIter
    selectObject all
    selectObject none
    #set hasModified 0
    #set hasModified 1
    # puts $location
    puts $pn
    puts $footprint
    selectObject none
    saveAll
    # sch::nextPage
    closeItem $lViewid
    incr pageIter
    puts "Done"
    sch::leaveBatchMode
    #saveAll
    #sch::closeProject
    #exit
