  2. Allegro X Scripting - TCL
  3. How to convert DSN to PDF with tcl?
  • State Verified Answer
  • Subscribers 14
  • Views 3121
Gelzone
Gelzone 10 months ago
In the OrCAD Capture CIS 23.1, I found there are 2 features that can make the DSN file to PDF format:
1. File > Print
2. File > Export > PDF
Both 2 meet my requirement, and I want to know if I can use tcl to make the process automatic, including setup the config like printer, orientation, printing mode, output path...
  • TechnoBobby
    TechnoBobby 10 months ago +1 verified
    Hi Gelzone , Yes, you can automate the PDF export process. Below is an example script you can customize: namespace eval ::ExportPDF {} package require OrHandlerPDFExport proc ::ExportPDF::StartPDFExport…
  • TechnoBobby
    +1 TechnoBobby 10 months ago
    Hi Gelzone ,
    proc ::ExportPDF::StartPDFExport {} {
    set FileName "sample.pdf"
    set lOutputDir "c:/Cadence"
    set lfirst "{{"
    set lLast "}}"      
    set var [ concat \"outputDirectory\"\: \"$lOutputDir\" \,\"outputPdfFile\"\: \"$FileName\" {,"postscriptFilePath":"OrCADPS_24.1","PStoPdfConverter":"Ghostscript 64 bit / equivalent","PdfExcludeProp":"Line Style!!Line Width!!Color!!Location X-Coordinate!!Location Y-Coordinate","PStoPdfCommand":"{c:/gs/gs10.02.1/bin/gswin64c.exe} -sDEVICE=pdfwrite -sOutputFile=$::capPdfUtil::mPdfFilePath -dBATCH -dNOPAUSE $::capPdfUtil::mPSFilePath","commandIndex":2,"printingMode":"0","orientation":"1","createPdfPropertiesFile":"0","createNetAndPartBookmarks":"1","PaperSizeIndex":0}]
    set var1 [concat $lfirst $var $lLast]
    eval "::OrHandlerPDFExport::printPDF $var1"  
    For additional details, refer to below article on ASK portal:
    Title: How can I export my design to PDF using a Tcl script?
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MgF1UAK&pageName=ArticleContent
    Hope it helps!
  • Gelzone
    0 Gelzone 10 months ago in reply to TechnoBobby
    Test OK, thanks!
