  2. Allegro X Scripting - TCL
  3. Can I catch any information while "Create Netlist" fail...
  • State Suggested Answer
  • Answers 1
  • Subscribers 14
  • Views 2126
Can I catch any information while "Create Netlist" fail with tcl?
Gelzone
Gelzone 10 months ago
I have used user-action tcl code (Menu "Tools::Create Netlist") to create netlist from DSN file in OrCAD.
Sometimes the process will fail due to the DSN content or config setting, and there will be a error message pop up and lock the procedure.
I wonder if there is any way to catch the error/exception while creating netlist and that can make me handle it well.
  • CadAP
    CadAP 9 months ago in reply to Gelzone +1 suggested
    catch {Menu "Tools::Create Netlist" | DialogBox "OK" "//Setup_cfg.xml" | DialogBox "OK" "//PCB_netlist.xml"} err puts $err if {$err ==1} { puts "failed" } else {puts "passed"}
  • CadAP
    0 CadAP 10 months ago
    Gelzone
    Try to put your command inside "catch" command.
    like below:
    catch {Menu "Tools::Create Netlist} err
    puts $err
    Try and let me know your feedback.
  • Gelzone
    0 Gelzone 10 months ago in reply to CadAP
    It doesn't catch any message.
    The error message box still pop up and lock the procedure until I press "OK".
    The snippets:
    if {[catch {Menu "Tools::Create Netlist" | DialogBox "OK" "//Setup_cfg.xml" | DialogBox "OK" "//PCB_netlist.xml"} err] } {
    puts "Netlist fail: $err"
    after 5000
    exit 1
  • CadAP
    0 CadAP 9 months ago in reply to Gelzone
    puts $err
    if {$err ==1} {
    puts "failed"
