  2. Allegro X Scripting - TCL
  3. Fail to open DSN with TCL due to both "dot" and "space"...
  • State Verified Answer
  • Subscribers 15
  • Views 2655
Fail to open DSN with TCL due to both "dot" and "space" in the file name
Gelzone
Gelzone 10 months ago
I try both Menu "File::Open::Design" and MenuCommand "57601" to open my file with tcl but fail.
The file name is "<project folder>/test_M.2 test1.DSN" and the error message shows something like "<project folder>/test_M.2 not found".
And I try to remove the "dot" (keep the "space"), the command can open the DSN file successfully.
Another experiment that keeping "dot" but remove "space" also works well.
So I think this file not found issue will occur when both "dot" and "space" exist in the file name.
  • CadAP
    CadAP 9 months ago +2 verified
    Gelzone , Please try the belwo command open { <project folder>/test_M.2 test1.DSN } It do open the project but space is not recommended in project name.
  • JCTEYSSIER0
    0 JCTEYSSIER0 10 months ago
    Space is a field separator at operating system level.
    A lot of problem occur if usinf this caracter in pathname or name.
    My advice is to use ONLY:
    a to z
    0 to 9
    underscore (_)
    dash (-)
    and no other caracters.
    By the way, be aware of file pathname length, operating system like windows handhle badly verry long name (in the past, file pathname were not or badly handheld is more than 255)
  • Gelzone
    0 Gelzone 10 months ago in reply to JCTEYSSIER0
    JCTEYSSIER0
    Thanks for reply.
    The DSN name is following my company's rule so I think it's not that easy to change the format. And the DSN name will affect the netlist content, so I ain't gonna to change it to a temp name.
  • CadAP
    +1 CadAP 9 months ago
    Gelzone ,
    open {<project folder>/test_M.2 test1.DSN}
    • Vote Up +2 Vote Down
  • Gelzone
    0 Gelzone 8 months ago in reply to CadAP
    CadAP
    Thanks for reply.
    Wow, it seems that OrCAD can use tcl built-in commands to open a project?
    I will keep this in mind.
    Also, I have asked for the format of the project name.
