  2. Allegro X Scripting - TCL
  3. TCL script to set a property value in all titleblocks in...
  • State Verified Answer
  • Answers 1
  • Subscribers 14
  • Views 2370
TCL script to set a property value in all titleblocks in a hierarchical design
Willy
Willy 9 months ago
I am attempting to write a TCL script that will set/update Title Block values in all Title Blocks in a schematic design.
I have been working through the OrCAD_Capture_TclTk_Extensions.pdf doc and googling. I can get the TCL script to find and run through all pages, but when I try to set or get property values I keep getting various errors depending on which examples/methods I am using.
I removed the prompting for values and just hard coded in a propName of YEAR (which definitely exists in all sheets/pages) to propValue of 2020 to make the script shorter/simpler for getting help. I have left in commented out different things I have tried.
Any help much appreciated, script below:
# Define the property name and new value
set propName "YEAR"
set propValue "2020"
set lDesign [GetActivePMDesign]
set lStatus [DboState]
set lNullObj NULL
# 2. Iterate through Schematic Folders
set lSchi_Name [DboTclHelper_sMakeCString]
if {$lDesign != $lNullObj} {
set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
#get the first schematic view
set lView [$lSchematicIter NextView $lStatus]
puts $lSchematicIter
set lPage_Name [DboTclHelper_sMakeCString]
puts $lPage_Name
while { $lView != $lNullObj} {
#dynamic cast from DboView to DboSchematic
set lSchematic [DboViewToDboSchematic $lView]
$lSchematic GetName $lSchi_Name
set lPagesIter [$lSchematic NewPagesIter $lStatus]
#get the first page
set lPage [$lPagesIter NextPage $lStatus]
puts [DboTclHelper_sGetConstCharPtr $lSchi_Name]
while {$lPage!=$lNullObj} {
#placeholder: do your processing on $lPage
$lPage GetName $lPage_Name
puts [DboTclHelper_sGetConstCharPtr $lPage_Name]
# set lTitleBlocksIter [$lPage NewTitleBlocksIter $lStatus]
# set lTitle [$lTitleBlocksIter NextTitleBlock $lStatus]
#while {$lTitle!=$lNullObj} {
#placeholder: do your processing on $lTitle
#puts $lTitle
# set lStatus [$lTitle SetEffectivePropStringValue "YEAR" "1999"]
#set lStatus [$lTitle GetEffectivePropStringValue "YEAR" $propValue]
# $lTitle GetEffectivePropStringValue $propName propValue
#puts "Property Value: $propValue"
#get the next title block
#set lTitle [$lTitleBlocksIter NextTitleBlock $lStatus]
#delete_DboPageTitleBlocksIter $lTitleBlocksIter
set pValue ""
# 3. Get the value of a specific property (e.g., "Title")
# GetEffectivePropStringValue takes (PropertyName, VariableToStoreValue)
set lStatus [$lPage GetEffectivePropStringValue "Title" pValue]
# 4. Check status and print result
if {$lStatus == 1} {
puts "Title Block Value: $pValue"
} else {
puts "Property 'Title' not found."
#placeholder: do your processing on $lSchematic
#puts $lSchematic
#get the next schematic view
delete_DboLibViewsIter $lSchematicIter
delete_DboSchematicPagesIter $lPagesIter
  • Willy
    Willy 9 months ago in reply to TechnoBobby +1 verified
    That is nothing like what I expected to see, thanks very much! I will see how I go adding the prompts and other variables back in.
  • TechnoBobby
    0 TechnoBobby 9 months ago
    Hi Willy ,
    Please try the TCL script below to update properties in all title blocks. For hierarchical designs, it’s important to get the occurrence of title block. Also, for both Get or SetEffectivePropStringValue, the property name and value must be passed as CStrings.
    Hope it helps!
    proc lGetOcc {lParent} {
    set lPartOcc {}
    set lOccCount [$lParent GetOccurrencesCount]
    for {set i 0} {$i < $lOccCount} {incr i} {
    set lOcc [$lParent GetOccurrencesAtPos $i]
    lappend lPartOcc $lOcc
    return $lPartOcc
    proc lUpdateTitleBlocksOnPage {lPage lPropNameCString lPropValueCString} {
    set lNullObj NULL
    # Iterate title blocks on this page
    set lTitleBlock [$lTitleBlocksIter NextTitleBlock $lStatus]
    while {$lTitleBlock != $lNullObj} {
    # For hierarchical designs / "yellow fields", update occurrences
    set lOccList [lGetOcc $lTitleBlock]
    if {[llength $lOccList] > 1} {
    foreach lOcc $lOccList {
    set lStatus [$lOcc SetEffectivePropStringValue $lPropNameCString $lPropValueCString]
    } else {
    # Flat case: update title block directly
    set lStatus [$lTitleBlock SetEffectivePropStringValue $lPropNameCString $lPropValueCString]
    proc UpdateAllTitleBlocksInDesign {propName propValue} {
    set lNullObj NULL
    # Get the session and active design
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lDesign [$lSession GetActiveDesign]
    if {$lDesign == $lNullObj} {
    puts "ERROR: No active design."
    return
    # Convert property name/value to CStrings
    set lPropNameCString [DboTclHelper_sMakeCString $propName]
    set lPropValueCString [DboTclHelper_sMakeCString $propValue]
    # For logging
    # Iterate schematics
    while {$lView != $lNullObj} {
    # Iterate pages
    while {$lPage != $lNullObj} {
    # Optional logging
    # puts "Updating: [DboTclHelper_sGetConstCharPtr $lSchi_Name] / [DboTclHelper_sGetConstCharPtr $lPage_Name]"
    # Update all title blocks on this page (flat + occurrences)
    lUpdateTitleBlocksOnPage $lPage $lPropNameCString $lPropValueCString
    puts "Done. Updated Title Block property '$propName' to '$propValue' everywhere."
    UpdateAllTitleBlocksInDesign "YEAR" "2020"
  • Willy
    +1 Willy 9 months ago in reply to TechnoBobby
  • Willy
    0 Willy 9 months ago in reply to Willy
    Hey TechnoBobby, one small issue is that it doesn't work on occurrences (the yellow highs). Not as issue for my usage at the moment but I noticed you had that implementation in your code
