  2. Allegro X Scripting - TCL
  3. TCL script for creating library, drawing rectangle and placing...
  • Subscribers 14
  • Views 2157
TCL script for creating library, drawing rectangle and placing pins, and saving .OLB
AT202409242847
AT202409242847 9 months ago
Currently I want an autoLoad TCL script that does the following
1. creates a new library and part
2. draws rectangle and some pins
3. exports to .OLB
I tried copying command journaling to get this:
set libDir "C:/Users/.../AppData/Roaming/SPB_Data/cdssetup/workspace/libraries/symbols"
set libPath "$libDir/LIBRARY1.OLB"
set outputPath "C:/syscap/output/test.olb"
set partName "TEST"
Menu "File::New::Library"
SelectPMItem "$libPath"
capLaunchNewSymbolEditor "$libPath" "$partName" 1 1
OrSymbolEditor::execute placeRectangle -0.4 0.7 0.4 -0.7
OrSymbolEditor::execute placeSymbolPin {OUT} {1} 2 Line {} -0.4 0.3 -0.5 0.3 true Scalar {{"UserPropAr":[]}}
OrSymbolEditor::execute placeSymbolPin {IN+} {3} 0 Line {} -0.4 0 -0.5 0 true Scalar {{"UserPropAr":[]}}
# Save library to output path
MenuCommand "29596" | FileDialog "OK" "$outputPath" 1
OrSymbolEditor::execute save 0
However, it fails on startup autoLoad with the Menu command giving MenuID not found. Which I assume is due to the script being run before the ui is initialized? Pasting the command into the command window manually works no issue...
I tried looking up how to do this using the Dbo commands, but only got as far as something like this:
set lSession $::DboSession_s_pDboSession
set lStatus [DboState]
DboSession -this $lSession
set newLib [$lSession CreateLib [DboTclHelper_sMakeCString "C:/syscap/output/test.OLB"] $lStatus]
set lLibraryPath [DboTclHelper_sMakeCString C:/syscap/output/test.OLB]
set lLib [DboSession_GetLibAndSchematics $lSession $lLibraryPath $lStatus]
If anybody could let me know how to run the script on startup without the menu issue or draft a TCL script for what I want to do, that would be greatly appreciated!
Many thanks in advance!
  • CadAP
    CadAP 9 months ago +1
    AT202409242847 Try the below suggestion if it helps: Load your tcl code after few secs(use after command)
  • CadAP
    0 CadAP 9 months ago
    AT202409242847
  • AT202409242847
    0 AT202409242847 8 months ago in reply to CadAP
    Thanks for the response!
    I tried the after command on the source .tcl script and on the .tcl file in autoLoad. Unfortunately, the issue persists, just that it occurs after stalling for whatever time I set (e.g. 5000 milliseconds). Seems like it waits for all the autoLoad programs to fully execute before loading the ui.
    Will likely need a different fix.
