  2. Allegro X Scripting - TCL
  3. New Part from XML
  • State Verified Answer
  • Answers 1
  • Subscribers 14
  • Views 3148
New Part from XML
YL202501275314
YL202501275314 9 months ago
This is Reference Code from Cadence Example.
And I would like to add PCB Footprint Information
How can I Find The information about xml ID ?
puts $lXmlFile {<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<DialogControls>
<Control Type="EDIT" Enable="TRUE" Visible="TRUE" Id="16009">}
puts $lXmlFile "<Value><!\[CDATA\[$lPartName\]\]></Value>"
puts $lXmlFile {</Control>
<Control Type="EDIT" Enable="TRUE" Visible="TRUE" Id="16006">}
puts $lXmlFile "<Value><!\[CDATA\[$lSecLength\]\]></Value>"
<Control Type="EDIT" Enable="TRUE" Visible="TRUE" Id="16012">
<Value><![CDATA[U]]></Value>
</Control>
<Control Type="GROUPBOX" Enable="TRUE" Visible="TRUE" Id="-1">
<Value><![CDATA[Part Numbering]]></Value>
</Control>
<Control Type="AUTORADIO_BUTTON" Enable="TRUE" Visible="TRUE" Id="16002">
<Value><![CDATA[0]]></Value>
<Text><![CDATA[N&umeric]]></Text>
</Control>
<Control Type="AUTORADIO_BUTTON" Enable="TRUE" Visible="TRUE" Id="16003">
<Value><![CDATA[1]]></Value>
<Text><![CDATA[A&lphabetic]]></Text>
</Control>
and I would like to add some Line in symbol
  • TechnoBobby
    TechnoBobby 8 months ago in reply to YL202501275314 +1 verified
    Hi YL202501275314 , Please try the script below. It retrieves the active library currently open in Capture and updates the specified package property on the specified part. Just ensure that no part is…
  • TechnoBobby
    0 TechnoBobby 9 months ago
    Hi YL202501275314,
    The code snippet appears to come from the Create Part from Spreadsheet Tcl script. In that, you cannot add or modify part properties. After the parts are created, you must traverse the parts within the .olb  library to update their properties.
    Please refer to the following article and update your script accordingly:
    Title: How can I add/delete one common property to/from all parts present in a library at once?
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nYBdEAM&pageName=ArticleContent
    Hope this helps!
  • YL202501275314
    0 YL202501275314 9 months ago in reply to TechnoBobby
    Dear TechnoBobby
    I added "add_prop_lib" the end of the TCL  code
    add_prop_lib {$lib_path} {test_item}{test_value}
    but the program has ended to caution.
    and there is no way to change package Footprint
  • TechnoBobby
    +1 TechnoBobby 8 months ago in reply to YL202501275314
    Hi YL202501275314 ,
    Please try the script below. It retrieves the active library currently open in Capture and updates the specified package property on the specified part. Just ensure that no part is opened in edit mode while running the script.
    Hope this helps!
    proc add_pkg_prop {PkgName lProp lValue} {
    set lStatus [DboState]
    set NullObj NULL
    set lCProp [DboTclHelper_sMakeCString $lProp]
    set lCValue [DboTclHelper_sMakeCString $lValue]
    # Get Active library
    set lSrcLib [GetActivePMLastLibrary]
    if {$lSrcLib == $NullObj} {
    puts "ERROR: No Active library"
    return
    # Iterate packages
    set lPkgIter [$lSrcLib NewPackagesIter $lStatus]
    set lPackage [$lPkgIter NextPackage $lStatus]
    while {$lPackage != $NullObj} {
    # Package name
    set pkgCStr [DboTclHelper_sMakeCString]
    $lPackage GetName $pkgCStr
    set Pkg_Name [DboTclHelper_sGetConstCharPtr $pkgCStr]
    if {$Pkg_Name== $PkgName} {
    $lPackage SetEffectivePropStringValue $lCProp $lCValue
    puts "Property: $lProp updated on Part: $Pkg_Name"
    # puts $lPackage
    delete_DboLibPackagesIter $lPkgIter
    # Example usage:
    add_pkg_prop "Part1" "PCB Footprint" "smdcap"
  • YL202501275314
    0 YL202501275314 8 months ago in reply to TechnoBobby
    Dear Bobby
    It's working well,
    And I would like to change Part Reference Prefix
    i tried
    add_pkg_prop "Part1" "Part Reference Prefix" "T"
    But it's not working
    Would you help it again
    Thank you
  • YL202501275314
    0 YL202501275314 8 months ago in reply to YL202501275314
    And I would like to add geometry
    in Symbol
    Would like to placeline x1 y1 x2 y2 like this
    but its not working in TCL code
    Would you give me a guide ?
