  2. Allegro X Scripting - TCL
  3. Audit OLB's in directory
  • State Suggested Answer
  • Answers 1
  • Subscribers 15
  • Views 2961
Mhawley1
Mhawley1 8 months ago
Hello Can anybody give me a boiler plate on batch opening OLB's .
I want to be able to open an OLB , read the names of all the symbols within and then close .
  • TechnoBobby
    0 TechnoBobby 8 months ago
    Hi Mhawley1 ,
    Please try below script. It reads the specified olb and prints the symbol names without opening the library in Capture.
    proc dump_pkg_name {libPath} {
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    set lStatus [DboState]
    set NullObj NULL
    # Open library in batch mode (command window)
    set cLibPath [DboTclHelper_sMakeCString $libPath]
    set lSrcLib [$lSession GetLib $cLibPath $lStatus]
    if {$lSrcLib == $NullObj} {
    puts "ERROR: Unable to open library: $libPath"
    return
    # Iterate packages
    set lPkgIter [$lSrcLib NewPackagesIter $lStatus]
    set lPackage [$lPkgIter NextPackage $lStatus]
    while {$lPackage != $NullObj} {
    # Package name
    set pkgCStr [DboTclHelper_sMakeCString]
    $lPackage GetName $pkgCStr
    set packageName [DboTclHelper_sGetConstCharPtr $pkgCStr]
    puts $packageName
    delete_DboLibPackagesIter $lPkgIter
    # Example Usage
    # dump_pkg_name {C:\TCL\LIBRARY1.OLB}
  • PatEscher
    0 PatEscher 8 months ago in reply to TechnoBobby
    open is 'relative'.
    This code does not necessarily open the olb in the user Interface, but it does open the OLB inside OrCAD, so a lock file is created.
    you need to make sure not keep any references open and close it, otherwise it will be locked till the end of the OrCAD session
  • Mhawley1
    0 Mhawley1 8 months ago in reply to TechnoBobby
    This is better than what I needed , I actually don't care to open the real file , I just want those names ! . Thank you Bob .
  • Mhawley1
    0 Mhawley1 8 months ago in reply to PatEscher
    I can cope with that , I dont actually want the file , just the names . So as long as I close the capture session , hopefully the Lock files are removed .
  • fSeyer
    0 fSeyer 7 months ago in reply to TechnoBobby
    any way to extract the pin count, pin numbers, pin name and xy positions of the selected part from the olb file?
